ViewSonic 43" CDE4302 109.2CM FHD
Quicklinx: BYB2WS00 Mfr#: CDE4302
  • 1080p
The ViewSonic CDE4302 is a 43'' Full HD direct-lit LED commercial display, offering the combination of cost-efficiency and ease of installation for corporate, retail and hospitality environments. With an integrated media player, the CDE4302 is able to easily playback high definition messaging via your USB port. Versatile connectivity options include 2 HDMI ports, VGA, RS232 and SPDIF. The display provides an easy one-time installation and is compatible with many different devices. With Full HD resolution, 350-nit brightness, and wide viewing angles, the slim-bezel CDE4302 delivers sharp and vivid images to ensure smooth content playback. This display also supports HDMI CEC pass-through for one-touch-play and an RS232 control port with IR pass-through for easy installation. The display is also equipped with exclusive eye-care technologies, including Flicker-Free and Blue Light Filter, creating a more comfortable viewing experience. Free-bundled vController software offers easy maintenance and an intuitive interface for remote management via a PC server or laptop.
  • Direct LED backlight technology for superior color performance
    ViewSonic's CDE4302 commercial display features direct LED backlight technology to deliver more accurate and consistent color performance while reducing energy consumption. The display provides superior color uniformity in any environment, as well as lowers overall cost of ownership which is ideal for corporate, SMB, retail, and restaurant uses.
  • Integrated USB multimedia player
    This display features an integrated media player with a convenient USB playback function. Now photos, music, and 1080p video can be quickly displayed on-screen directly from a USB drive - without the need for a PC.
  • Superior screen performance
    Featuring a 1920 x 1080 Full HD resolution and 350-nit brightness, the CDE4302 provides superior screen performance for in-door environments. The display also features wide viewing angles, delivering accurate, vivid colors and consistent color performance with no distortion or decay.
  • Advanced dual speakers for crystal-clear sound
    CDE4302's 10 W speaker design delivers incredible sound for high-quality sound effects - creating a lasting audio-visual impression on your target audience or demographic.
  • IR pass-through for multi-device control
    The CDE4302's RS232 control port features IR pass-through to provide automated control for hospitality and commercial display installations. IR pass-through offers local control for set-top boxes or other connected devices, directly with the display's remote controller.
  • HDMI CEC opens a world of HDMI possibilities
    With HDMI CEC functionality, remote controller signals can be transmitted via HDMI cable to connected HDMI devices. This enables out-of-sight DVD players, sound systems, and other devices to be directly controlled with the display's remote controller for a wider range of viewing possibilities.
ViewSonic CDE4302 43" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control, vController software
Voltage
Power Consumption (On mode)
105 W
Power Consumption Stand by
0.5 Watt
96.82 cm x 5.99 cm x 55.94 cm
8.7 kg
Environmental Standards
ENERGY STAR Qualified
105 W
Diagonal Class
43"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep
96.82 cm
5.99 cm
55.94 cm
8.7 kg
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-glare, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Backlight Life
30,000 hour(s)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm, 400 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Audio Controls
Equalizer, balance
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
VGA input , RS-232 , 2 x HDMI input , USB 2.0 , Headphones , Audio line-in , SPDIF output , IR Blaster
VGA cable
C-Tick, CB, FCC, WEEE, cTUVus, ERP
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
107 cm
Depth (Shipping)
15.9 cm
Height (Shipping)
69.6 cm
Weight (Shipping)
12.2 kg
20 - 80% (non-condensing)
