Sharp's PN-U473 professional LED display clearly has what it takes to get your message across. Designed for maximum impact, built for 24/7 durability, and sized for flexible installation, this 47 inch class display represent a dynamic indoor digital signage solution. Thin and lightweight enough to ensure an easy fit in stores, offices, and public spaces, the PN-U473 display boasts the outstanding image quality needed to deliver truly compelling signage.
- Sharp PN-U473 PN series - 47" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- 130 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 108.3 cm x 5.5 cm x 62.7 cm
- 19 kg
- Product Type
- 130 Watt
- Diagonal Class
- 47"
- Commercial Use
- Series
- PN series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, DisplayPort
- HDCP Compatible
- Modes
- Portrait mode, landscape mode, Mirror Display Mode
- Dimensions
- Without stand
- 108.3 cm
- 5.5 cm
- 62.7 cm
- 19 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1300:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 12 ms
- Certified for 24/7 Continuous Operation
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- DVI-D input , HDMI input , Component video input , DisplayPort input , Composite video input , DVI-D output , Audio line-in , LAN , Audio line-out , Serial input , Serial output
- Plug and Play
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- 0 °C
- 40 °C
- 20 - 80%
