Sharp PN70TB3 70" 1920x1080 VGA DVI HDMI DP LCD LFD
Quicklinx: 9VN9WS00 Mfr#: PN70TB3
  • 1080p
Sharp's BIG PAD interactive touch screen monitor PN-70TB3 is designed for smooth and effortless communication in a wide range of contexts. The highly responsive touch pen technology allows several people to write on the same screen at the same time.
  • Simultaneously writing
    Recognizing up to 10 points of contact, the PN-70TB3 multi-touch LCD monitor allows up to four people to write on the screen at the same time using touch pens or fingers. Participants can take an active part in meetings, brainstorming sessions, classroom interactions and more.
  • Smooth, highly responsive touch pen
    The dedicated touch pen with function buttons writes so smooth and light that using it is like writing on paper. A pressure sensor at the tip of the slim and lightweight pen lets you write with high precision and with an effortless and uninterrupted flow.
  • Handwriting recognition
    This LCD monitor features a handwriting recognition function for converting selected onscreen handwriting to standard text. This convenient function allows you to utilize onscreen content to make neat and legible minutes of your meetings.
  • Touch-operated onscreen display
    Pressing the touch menu button displays an onscreen menu that lets you easily switch input sources, change volume level, or turn the touchscreen function on and off without using a remote control.
Sharp BIG PAD PN-70TB3 70" Class (69.5" viewable) LED-backlit LCD display - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Input Video Formats
1080p
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15), DisplayPort
HDCP Compatible
UV²A
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, 2 AA batteries, eraser, camera mounting kit, pen tray, blank sticker, electronic touch pen, 5 x cable clamps
Voltage
225 Watt
164.7 cm x 9.4 cm x 101 cm
59 kg
225 Watt
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Landscape mode
Design
Fanless Design
Dimensions
Without stand
164.7 cm
9.4 cm
101 cm
59 kg
Enclosure Colour
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Coating
Anti-glare
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
3000:1
Brightness
300 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
160 degrees
Pixel Pitch
0.802 x 0.802mm
Touchpoints Qty
10
Response Time
6 ms
Certified for 24/7 Continuous Operation, Quick Start, infrared blocking detection, Touch Display Link 2.0 software
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Input Video Formats
1080p
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connect & Share
USB Human Interface Device (HID)
Connector Type
USB 2.0 - side , VGA input - side , 2 x HDMI input - side , Audio line-in - side , Speakers output - bottom , Audio line-out - bottom , DisplayPort output - bottom , USB - bottom , USB 2.0 - bottom , LAN - bottom , VGA input - bottom , DisplayPort input - bottom , HDMI input - bottom , Audio line-in - bottom
USB cable - 3 m
Plug and Play, DDC-2B, VESA DPMS
Power supply
Input Voltage
5 °C
35 °C
20 - 80% (non-condensing)
