Sharp PN70SC3 70" 1920x1080 Touchscreen LED LFD
Quicklinx: BQJFWS00 Mfr#: PN70SC3
  • 1080p
The Sharp BIG PAD PN-70SC3 is the ideal model for higher education campuses and corporate office applications. Offering state-of-the-art collaboration with outstanding price performance, Sharp’s next generation 70" BIG PAD is optimized for the campus and SME environment to enhance communication and create the best conditions for effective collaboration.
Whether in a classroom or a meeting room, it can sometimes be a challenge to keep everyone focused and engaged. That's where Sharp's innovative BIG PAD PN-70SC3 comes in. The generous Full HD 70" touchscreen monitor lets you display, create and collaborate with ease and precision.
The acclaimed, smart and intuitive pen software opens up new ways for brainstorming, sharing ideas and finalizing decisions. Powerful, flexible and surprisingly cost-effective, the latest Sharp BIG PAD PN-70SC3 provides an outstanding platform to either boost collaboration, enhance audience impact, or simply increase meeting effectiveness in the corporate office or campus environment.
Sharp BIG PAD PN-70SC3 70" Class (69.5" viewable) LED-backlit LCD display - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
UV²A
LCD Backlight Technology
Edge-lit LED
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, 2 AA batteries, eraser, 2 x cable clamps, Sharp Pen Software, pen tray, blank sticker, electronic touch pen
Voltage
235 Watt
163.3 cm x 10.9 cm x 99.45 cm
56 kg
235 Watt
Diagonal Class
70"
Diagonal Size
69.5"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Whiteboard mode
Protection
Protection glass
Dimensions
Without stand
163.3 cm
10.9 cm
99.45 cm
56 kg
Display
LCD Display Technology
UV²A
Resolution
1920 x 1080
Edge-lit LED
Colour Depth
16.8 million colours
Image Contrast Ratio
3000:1
Brightness
300 cd/m²
Viewing Angle
160 degrees
Viewing Angle (Vertical)
160 degrees
Pixel Pitch
0.802 x 0.802mm
Touchpoints Qty
6
Response Time
6 ms
Infrared blocking detection, handwriting recognition, Certified for 16/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
PAL, SECAM, NTSC 3.58, NTSC4.43, PAL60
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Connector Type
USB 2.0 , VGA input , 3 x HDMI input , Audio line-in , Component video input , Composite video input , 2 x audio line-in , Audio line-out , Serial input
USB cable
Plug and Play, DDC-2B
Power supply
Input Voltage
5 °C
35 °C
20 - 80% (non-condensing)
