The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
2.5-inch HDDs improve data center storage efficiency
Make the transition from legacy 3.5-inch form factor drives with limited capacities and slower performance to the higher density, faster and best-in-class Enterprise Performance 10K HDD. With up to 2x the capacity and a smaller footprint, data centers can store and access data faster than ever, enabling them to keep pace with data growth while optimizing scarce IT real estate. Lower power consumption reduces energy and cooling costs. -
Enhanced storage reliability with improved storage efficiency
Seagate Enterprise Performance 10K HDD advanced media management technology improves drive reliability and data integrity. This seventh-generation hard drive with features like a humidity sensor and SuperParity, lets you rest easier knowing your storage devices will perform as expected - even in harsh environments. -
Protect data with built-in security at no additional charge
Seagate Enterprise Performance 10K drives are self-encrypting drives (SED) and can be used as standard drives or as part of a more secure solution at no extra cost. Built-in security, FIPS2 validated security and Protection Information features enable companies to protect valuable data, comply with regulatory mandates, and reduce risk to brands and reputations. Seagate instant secure erase feature reduces the time required to overwrite a drive - from hours to less than a minute - making drive retirement safe, fast and easy.
- Seagate Enterprise Performance 10K HDD ST1200MM0118 - hard drive - 1.2 TB - SAS 12Gb/s
- Hard drive - internal
- Capacity
- 1.2 TB
- NAND Flash Memory Type
- Enterprise multi-level cell (eMLC)
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Buffer Size
- 128 MB
- Spindle Speed
- 10000 rpm
- PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Seagate TurboBoost, S.M.A.R.T.
- 70.1 mm x 100.45 mm x 15 mm
- 193 g
- 5-year warranty
- Capacity
- 1.2 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 12Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 4096
- 70.1 mm
- 100.45 mm
- 15 mm
- 193 g
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Internal Data Rate
- 241 MBps
- Average Latency
- 2.9 ms
- Spindle Speed
- 10000 rpm
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^16
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 2.5" SFF
- Power Consumption
- 4.26 Watt (idle) , 7.25 Watt (active)
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance (operating)
- 40 g @ 11 ms
- Shock Tolerance (non-operating)
- 400 g @ 2 ms
