Seagate 6TB BarraCuda SATA 6GB/s 5400RPM Hard Drive
Quicklinx: D9WYWS00 Mfr#: ST6000DM003
Form Factor: 3.5
Type: Hard drive
Interface Type: [N/A]
Capacity: 6TB
Spin Speed (rpm): 7200rpm
Select:
  • 6TB
£162.28 ex VAT
£194.73 inc VAT
The Barracuda family has earned awards and accolades around the globe. This is because Seagate has demonstrated a commitment to introduce technologies that allow people to work faster, do more, and feel great about making an investment in proven technology. And, for those who want the biggest, high performance drive available, the Barracuda choice is without peer.
Versatile. Fast. Dependable
BarraCuda leads the industry with the highest capacities for desktops and mobile computers. With drives available up to 12 TB, the BarraCuda portfolio is a great option for upgrades at any price point. The uncompromising BarraCuda Pro marries industry-leading storage capacity with 7,200-RPM spin speeds for snappy performance and load times when gaming or performing heavy workloads. BarraCuda Pro also comes equipped with a 5-year limited warranty.
3.5-Inch BarraCuda Hard Drives Deliver
Rock-solid reliability built on over 20 years of BarraCuda innovation. Versatile mix of capacity and price point options to fit any budget. Multi-Tier Caching Technologyâ„¢ for excellent hard drive performance.
All hard drives in the BarraCuda family come equipped with Multi-Tier Caching Technology (MTC). MTC takes your PC to new performance levels, so you can load applications and files faster than ever before. By applying intelligent layers of NAND Flash, DRAM and media cache technologies, BarraCuda delivers improved read and write performance by optimising data flow.
  • Versatile HDDs for all your PC needs bring you industry-leading excellence in personal computing.
  • For over 20 years the BarraCuda family has delivered super-reliable storage for the hard drive industry.
  • Capacities up to 8 TB for desktops, BarraCuda leads the market with the widest range of storage options available.
  • Advanced Power modes help save energy without sacrificing performance.
  • SATA 6 Gb/s interface optimises burst performance.
  • Robust storage capacity
    With a generous 6 TB capacity, this hard drive provides ample space for storing large files, high-resolution images, and extensive software libraries, making it a suitable solution for professionals and enthusiasts alike.
  • Durable design
    Engineered to withstand the rigors of daily use, this hard drive features a high tolerance for shock and vibration during operation and non-operation, ensuring your data remains safe even in challenging conditions.
  • Efficient performance
    Boasting a data transfer rate of up to 600 MBps and advanced features like Native Command Queuing (NCQ) and TGMR recording technology, this hard drive delivers efficient and reliable performance for everyday computing needs.
Seagate Barracuda ST6000DM003 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Native Command Queuing (NCQ), PIO mode 0-4 support, Multi-Word DMA mode 0-2 support, Ultra DMA Mode 0-6 support, Hot-Plug Support, Worldwide Name (WWN), TGMR recording technology, S.M.A.R.T.
101.6 mm x 146.99 mm x 26.1 mm
610 g
6 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
Bytes per Sector
4096
101.6 mm
146.99 mm
26.1 mm
610 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
190 MBps
Average Latency
6 ms
Reliability
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.3 watt (read) , 3.4 watt (idle) , 5.3 watt (write) , 0.25 watt (standby) , 0.25 watt (sleep)
Software Included
Seagate SeaTools
RoHS, China RoHS
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
5 - 90%
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (operating)
0.5 g @ 22-350 Hz
Vibration Tolerance (non-operating)
3 g @ 22-350 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 6TB
Brand: Seagate
