Brand
Seagate 1TB SkyHawk 3.5" SATA 6Gb/s 64MB Surveillance Hard Drive
Quicklinx: CH06WS00 Mfr#: ST1000VX005
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 1TB, 1TB
Spin Speed (rpm): 5900rpm
24 In Stock
£41.25 ex VAT
£49.50 inc VAT
Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Seagate SkyHawk Surveillance HDD ST1000VX005 - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5900 rpm
24x7 availability, ImagePerfect firmware
101.85 mm x 146.99 mm x 20.2 mm
415 g
3-year warranty
1 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.85 mm
146.99 mm
20.2 mm
415 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
180 MBps
Spindle Speed
5900 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5"
Power Consumption
1.8 Watt (start) , 5.6 Watt (active) , 4 Watt (idle) , 0.5 Watt (sleep) , 0.5 Watt (standby)
Limited warranty - 3 years
70 °C
Form Factor: 3.5
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: Seagate
