The Seagate Enterprise NAS HDD is designed to combine industry-leading capacity with reliability and performance. Designed for mid-range enterprise and private cloud environments, this NAS HDD delivers sustained performance for global availability and 24×7 accessibility.
Industry-leading drive capacity
The high-performance Enterprise NAS HDD is available in a single NAS drive, helping to lower the total cost of ownership by using fewer drives and rackmount systems. -
Maximized reliability for your critical data
Reliability has never been more important to your business. The Enterprise NAS HDD has more reliability features and options that help to ensure your data is safe. -
Seriously robust performance
NAS environments demand a unique combination of performance and reliability. Designed for performance with workgroups of more than 25 users, the Enterprise NAS HDD includes higher write workloads for NAS-optimized performance, RV sensor for drive head control and vibration control and 3D motor balancing for optimum performance in multi-drive solutions. -
Best-fit enterprise NAS applications
Global business ecosystems require data agility for collaboration. Ideal for environments that require 24×7 availability and accessibility, the Enterprise NAS HDD is designed to manage aggressive workloads in enterprise environments.
- Seagate Enterprise NAS HDD ST4000VN0001 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 128 MB
- Spindle Speed
- 7200 rpm
- Dual Stage Actuator (DSA), Seagate AcuTrac technology, Seagate RAID Rebuild, Humidity Sensor, Low Halogen, Super Parity, Hot-Plug Support, Power Balance technology
- 101.85 mm x 147 mm x 26.1 mm
- 635 g
- 5-year warranty
- Capacity
- 4 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 128 MB
- Bytes per Sector
- 512
- 101.85 mm
- 147 mm
- 26.1 mm
- 635 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 216 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9.42 Watt (read) , 6 Watt (idle)
- Limited warranty - 5 years
- 0 °C
- 60 °C
- Vibration Tolerance (non-operating)
- 5 g @ 10-500 Hz
