Sandberg Network Cable UTP Cat6 10 m
Quicklinx: 6JXYWS00 Mfr#: 506-97
RJ45 UTP patch network cable is used to connect a computer to a broadband modem/LAN/switch etc. Can also be used between switches and in distributor boxes. The CAT6 standard is an improved version of CAT5e, specially designed to support 1000 Mbit/s Ethernet with an optimal transfer rate and minimal data packet loss. The cable also supports 10 and 100 Mbit/s Ethernet, which enables the speed to be optimized.
Sandberg network cable - 10 m
Network cable - CAT 6
Unshielded twisted pair (UTP)
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Length
10 m
Connector
RJ-45 - male
RJ-45 - male
