StarTech.com OM3 Multimode Fiber Cable
Quicklinx: HKKRWS00 Mfr#: A50FBLCSC1
Length: 1m
Colour: Aqua
£13.91 ex VAT
£16.69 inc VAT
N/A. Perfect for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment, this high speed 10 Gigabit Multimode Duplex Fiber Cable is terminated with LC and SC connectors, and is composed of 50/125 micron OM3 aqua fiber to deliver reliable data transfers at blinding speeds.
Suited for a broad range of environments, A50FBLCSC1 is housed in a flame retardant, LSZH (Low-Smoke, Zero-Halogen) cable jacket, taking safety to a new level by ensuring minimal smoke, toxicity and corrosion in the event of a fire - making it the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
  • High compatibility
    Designed to seamlessly integrate with PC systems, this 1m Fiber Optic Cable ensures a reliable connection between devices, enhancing your network's efficiency and performance.
  • Enhanced safety
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable minimizes the amount of toxic and corrosive gas emitted during combustion. It's an ideal choice for environments where safety and air quality are critical.
  • Superior connection quality
    With duplex 50 / 125 micron core/cladding diameter and multimode technology, this cable supports high-speed data transmission, making it perfect for bandwidth-intensive applications.
StarTech.com 1m Fiber Optic Cable - 10 Gb Aqua - Multimode Duplex 50/125 - LSZH - LC/SC - OM3 - LC to SC Fiber Patch Cable - patch cable - 1 m - aqua
Patch cable
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
1 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
2 x SC multi-mode - male
Aqua
Network Cable Type
Patch cable
Duplex fibre optic
Multimode
Jacket Material
Fibre Qty
2
50 / 125 micron
Length
1 m
Aqua
Connector
RoHS
HKKR StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - SC In Stock £16.15
Length: 1m
Colour: Aqua
