Samsung Xpress C1860FW Colour Laser Multifunction Printer
Quicklinx: B2ZPWS00 Mfr#: SL-C1860FW/SEE
Print wirelessly and share effortlessly with the Samsung Xpress C1860FW. All it takes is a simple tap of the advanced NFC technology, and the Samsung Mobile Print App allows you to take advantage of the powerful mobile features. Simply tap your mobile device to the Samsung Xpress C1860FW to print virtually any content.
Whatever size your team, and however busy you are, you can rely on the C1860FW to constantly deliver professional, quality color output. Because anything less isn't good enough.
  • Makes your smartphone even smarter
  • Get print on tap
  • Scan
    Scan images and send them directly to your mobile device.
  • Fax
    Share the content on your mobile device instantly via fax.
  • Print anywhere with Google Cloud Print
    Effortless mobile printing with impressive compatibility, optimized for any task or occasion. Google Cloud Print works on smartphones, tablet PCs, Google Chromebooks, PCs and other web connected devices.
  • Simple registration to Google Cloud
    Google Cloud Print allows you to connect and print from wherever you are. Just tap your smartphone to the printer and automatically connect it to the cloud - no login necessary.
  • No need to call for service
    Confusing error messages are a thing of the past. Just tap your NFC-enabled smartphone to the printer and you'll be guided through a step by step series of troubleshooting images or videos so you can get to work faster.
  • Enjoy professional color output
  • Make sharp images and text even sharper
    Boost the overall quality and vividness of your output with unique ReCP (Rendering Engine for Clean Pages). It automatically adds dots along the edges of images and characters, meaning everything looks so much sharper and cleaner. What's more, those white gaps between colored areas that are so common with other devices are eliminated. What you and your team are left with is an outstanding color output.
  • Make colors more vibrant
    The advanced Polymerized Toner formulation has smaller and more uniform particles, giving lines extra definition, and color more impact. Its higher wax content not only improves mage gloss, but also enhances print durability by preventing unwanted fading. And as the polymer toner can be applied in a thinner layer with lower fusing temperatures, it reduces the paper curl and energy consumption as well.
  • A higher level of printing performance
    Accelerating your business' productivity begins with your printer. With its 19/19 pages per minute output and a first page out time as low as 16 seconds the C1860FW delivers where it counts.
  • More power, better productivity
    With the power of two cores the device can process files simultaneously and the 256MB memory ensures large print jobs won't slow it down.
  • An easier user experience for you
    Let's face it; your time is too precious to waste standing around a printer for hours on end. So from operation to support software tools, you're in total control with this easy-to-use, multi-function device. It all revolves around 4.3" color touchscreen. It's clear, simple-to-read and it has never been easier to track your print jobs and activate every unique feature.
Samsung Xpress C1860FW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Printing Speed
Max Printing Resolution
9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper, cotton paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n)
42 cm x 42.6 cm x 44.8 cm
21.44 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Printing
Max Printing Speed
Printer Drivers / Emulations
PostScript 3, PCL 5c, SPL, PDF 1.7, PCL 6C
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Delayed Transmission
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), multi-send
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 98 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
ADF - 50 sheets size: 142 x 148 mm - Legal (216 x 356 mm) , Paper cassette - 250 sheets size: 98 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 19 ppm (Letter A) - B/W , Copying: up to 18 ppm (A4) - colour , Copying: up to 19 ppm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.9
380 Watt
Power Consumption Standby
50 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
42 cm
42.6 cm
44.8 cm
21.44 kg
Sound Emission
32 dBA (idle) / 52 dBA (operating)
