SHAPE wireless audio system lets you integrate music around how you live. Whether it's a single speaker in one room, or a multi room system in two rooms or every room in your home, it's never been easier to immerse yourself in your favorite sounds.
With its adaptive design, exceptional audio performance, and simple wireless connectivity, the speaker reinvents how you listen. Getting started is easy - plug in the speaker, connect your device via Bluetooth or Wi-Fi with the free app, and start listening.
The SHAPE wireless speaker
With its adaptive design, exceptional audio performance, and simple wireless connectivity, the speaker reinvents how you listen. Getting started is easy - plug in the speaker, connect your device via Bluetooth or Wi-Fi with the free app, and start listening. -
Designed for flexibility
The unique triangular design fits your home; on a shelf, in a cabinet, or tucked into the corner. Use one speaker horizontally for stereo audio or a pair vertically for true left/right separation. -
Bluetooth 3.0 + NFC
Send your music directly from your Bluetooth enabled smartphone, tablet, computer or Samsung TV to a shape speaker. You can even simply tap to connect with your NFC enabled devices to establish an instant wireless connection. -
TV SoundConnect
Enhance your TV's sound quality without the hassle of wires. Simply connect your TV SoundConnect enabled Samsung TV to a shape wireless speaker to instantly take your TV's audio to the next level. -
Music library
The easy to use app lets you access and play your music all in one place. Listen to your music library, the millions of songs from Internet radio or the music streaming services you subscribe to. -
Dual band Wi-Fi
The app uses dual band Wi-Fi to stream your music, whether to a single speaker, or to multiple speakers throughout your home. Dual band Wi-Fi provides a stronger signal to ensure the best possible sound experience. -
Multiroom system
When you add more speakers and a Hub, the SHAPE Multiroom system really comes to life. It's a Plug and Play system, where you can add speakers throughout your home, and take complete control of your music. -
Samsung SHAPE wireless audio hub
The hub, a small stand alone box, works with the app to allow you to connect multiple speakers into a multiroom system. By simply plugging the hub into your router and connecting via the app, you can connect, group and control your speakers to customize your music to fit your life. -
Zone play/party play
Using the hub, app, and multiple speakers, you have incredible flexibility in how you choose to play your music. Play one song in one room, different songs from different sources in each room, one song across all speakers, or any combination that fits your mood. -
Easy set up
Unlike yesterday's complex systems that require wiring your home, complex integration, or multiple network connections, it's quick and easy to set up a true multi-room audio system with SHAPE.
- Samsung SHAPE M5 - speaker - wireless
- Product Type
- Speaker
- Internet radio
- Speaker Type
- Active
- Amplifier
- Integrated
- Fast Ethernet, Bluetooth, Wi-Fi, NFC
- DLNA
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- White
- Built-in Decoders
- Dolby Digital Plus
- 34.25 cm x 16.8 cm x 11.32 cm
- 2.3 kg
- Product Type
- Speaker
- Internet radio
- Enclosure Colour
- White
Speaker System
- Speaker Type
- Active
- Amplifier
- Integrated
- IEEE 802.3u (Fast Ethernet), Bluetooth, Wi-Fi, Near Field Communication (NFC)
- DLNA
- Recommended Placing
- Wall-mountable
- Built-in Decoders
- Audio Formats
- Controls
- Mute, volume
- Additional Features
- Samsung AllShare technology, software update via USB, smartphone remote controlled, TV SoundConnect technology
Speaker System Details
- Driver Details
- Speaker: woofer driver - 3.15" , Speaker: 2 x tweeter driver - 2.2"
- Connector Type
- LAN (RJ-45)
- Included Accessories
- Power adapter, stand
- Power Source
- AC power adapter
- 15 Watt
- 34.25 cm
- 16.8 cm
- 11.32 cm
- 2.3 kg
