Pioneer DM-40D Speakers White
Quicklinx: J4SWWS00 Mfr#: DM-40D-W
£124.17 ex VAT
£149.00 inc VAT
Easy To Use
This is the perfect monitor speakers to usewith different DJ or production equipment; With RCA, mini jack, and the newly added TRS input terminals, you can connect different kinds of gear such as DJ controllers and mixers, or the laptop or soundcard you use; Connecting your headphones is simple via the socket on the front panel and the level knob is right in front of you too
Innovative Design
The grooves on the ducts reduce air friction so bass is tight and punchy, even if you position the speakers against a wall; Plus, the curved front edges provide maximum rigidity and minimum resonance for clean audio at any volume level
Two Way Sound Mode for DJing and Music Production
With the flip of a switch, artists can choose either DJ Mode or Production mode and the DSP settings optimize for the task
Easy to Use with Different DJ or Production Equipment
With RCA and mini-jack terminals, artists can connect different gear such as DJ controllers, mixers, laptops or the built-in sound card artists use for music production
Pioneer DJ DM-40D-W - monitor speakers
Monitor speakers
System Components
2 speakers
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Amplifier Output Power
2 x 19W - D
Amplifier
Integrated
White
AC 110-240 V (50/60 Hz)
Monitor speakers
Enclosure Colour
White
Enclosure Design
Bass reflex
Enclosure Material
MDF
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Amplifier Input Impedance
10 kOhm
Amplifier
Integrated
Amplifier Class
D
2 x 19W
Transmission Range
10 m
Headphone Output Jack
Speaker System Details
Driver Details
Speaker: woofer driver - 4" - fibreglass , Speaker: tweeter driver - 0.75" - Soft Dome
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) ¦ Audio line-in (RCA x 2) ¦ Headphones (mini-phone stereo 3.5 mm)
3.5 mm to RCAx2 cable
Power Source
Integrated power supply
25 Watt
Dimensions (WxDxH) / Weight Details
Left channel speaker: 14.6 cm x 22.3 cm x 22.7 cm / 2.5 kg ¦ Right channel speaker: 14.6 cm x 21.2 cm x 22.7 cm / 2.2 kg
Brand: Pioneer
