Samsung UD46C-B 46" 1920x1080 VGA DVI HDMI DisplayPort VESA 450CD LED Large Format Display
Quicklinx: 9HN6WS00 Mfr#: LH46UDCBLBB/EN
  • 1080p
UD-C series displays are factory tuned for brightness, color temperature and gamma. They deliver optimal uniformity and impressive images right out of the box.
The minimized bezel gap of just 5.5 mm is crucial to the virtually seamless video wall experience that the UD-C series delivers. It's ideal for control rooms, the medical sector, and conference rooms, broadcasting stations, transportation hubs, lobbies and retail.
  • Advanced color calibration
  • DisplayPort 1.2
    The digital loop out feature allows you to easily share content across video walls up to 10x10; including the ability to fully support Ultra High Definition resolution on 2 x 2 video walls. It is an easy and cost effective way to connect multiple displays.
  • Sharp, bright, impactful
    Full HD 1920 x 1080 resolution and brightness ensure a clear, vibrant video wall that's easy to look at and hard to ignore.
  • Direct-lit LED
    Direct-lit LED technology with a new backlight dimming solution allows the UD-C series display to achieve deeper blacks, higher contrast ratio of 3500:1, and power savings of up to 30%.
  • Ultra-slim bezels, virtually seamless video walls
Samsung UD46C-B UDC-B Series - 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote control
Voltage
Energy Class
Class C
130 Watt
Power Consumption (On mode)
120 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
175 kWh
102.37 cm x 9.55 cm x 57.83 cm
18.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Energy Class
Class C
130 Watt
120 W
175 kWh
Diagonal Class
46"
Commercial Use
Series
UDC-B Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
102.37 cm
9.55 cm
57.83 cm
18.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
3500:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
6.5 ms
Certified for 24/7 Continuous Operation, Lamp Error Detection, anti-image retention
Video Wall
100
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Component video input , Composite video input , Audio line-in , DVI-D output , Audio line-out , Serial , Remote control , Remote control/ambient sensor input
VGA cable
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, GOST, DDC-2B, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, CAN/CSA-C22.2 No. 60950-1
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
125.5 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
79.8 cm
Weight (Shipping)
31.2 kg
10 - 80%
