Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
Optimize the functionality and longevity of LFDs
In today's unstable economic environment, businesses are constantly looking for ways to do more with less and to enhance equipment functionality with as little expenditure as possible. Samsung overlay accessories can upgrade a company's existing LFDs and eliminate the need to purchase new displays. -
Add value to an LFD with quick overlay installation
Samsung overlay accessories offer installation that is designed to be quick and uncomplicated. The installation process enables businesses to upgrade LFDs within minutes, as compared to competitor all-in-one products that require additional steps. Samsung overlay accessories are lighter, slimmer and less expensive than most conventional LFDs that have touchscreen and protective glass features. -
Transform existing LFDs into interactive touchscreens
The Touchscreen Overlay accessory converts a standard LFD into a touchscreen LFD for a more interactive viewing experience. A special treatment on the front of the panel provides a realistic writing experience that is similar to writing on a conventional whiteboard.
- Samsung Touch Overlay CY-TE75 - touch overlay
- Touch overlay
- Connectivity Technology
- Wired
- 173.82 cm x 4.5 cm x 101.65 cm
- 26.6 kg
- Multi-Touch
- Movement Detection Technology
- Infrared
- Glass display overlay, 6-point simultaneous touch, aluminium body
- Designed For
- Samsung ED75C, ED75D
- Touch overlay
- 173.82 cm
- 4.5 cm
- 101.65 cm
- 26.6 kg
Input Device
- Wired
- Infrared
- Multi-Touch
- Included Accessories
- Pen tray, stylus pen
- Software Included
- Magic IWB 2.0 Basic
- Designed For
