Samsung Touch Overlay turns the display into an interactive board with dual drawing performance and allows for integrators and businesses to quickly add touch capabilities without the need to replace the display. The Touch Overlay seamlessly attaches to the frame of the bezel enabling a fully integrated touch display solution.
- Samsung Touch Overlay TM55BCC - touch overlay - black
- Touch overlay
- Connectivity Technology
- Wired
- Black
- 126.7 cm x 3.21 cm x 73.57 cm
- 9.5 kg
- Multi-Touch
- Movement Detection Technology
- Infrared
- Glass display overlay, 6-point simultaneous touch, aluminium body
- Touch overlay
- 126.7 cm
- 3.21 cm
- 73.57 cm
- 9.5 kg
- Black
Input Device
- Wired
- Infrared
- Multi-Touch
- Software Included
- Magic IWB 2.0 Basic
