Samsung Smart Home Camera HD Outdoor
Quicklinx: BBY6WS00 Mfr#: SNH-E6440BN/EX
  • microSD Card
  • microSDHC Card
2M (Full HD) SNH-E6440Bn camera helps you to monitor a clearer and brighter video. The visual angle of 128 degrees can provide wide monitoring coverage for your camera. If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area.
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network.
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
The product is water/vibration proof (IP66), and it can be installed in an outdoor area or outside the home.
  • High resolution video
    2M (Full HD) helps you to monitor a clearer and brighter video.
  • Wide angle
  • Motion zone detection
  • Saving in the memory card
  • Easy installation
  • Real-time alarm
    It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer.
  • Bi-directional audio
  • Night vision (5m)
    In poorly lit areas, the IR LED is operated automatically to brighten dark images.
  • Clear color
    IR Cut Filter switches between day and night to provide clearer color images.
  • Installable outside
  • Main body/camera detachable design
    If you are outside the home in an area where Wi-Fi signals are weak, you need to install a camera and if you are at home with a strong Wi-Fi signal, then you need to install the main body, so that it can be easily used where the Wi-Fi signals are weak.
Samsung Techwin SmartCam SNH-E6440BN - network surveillance camera
Network surveillance camera - fixed - outdoor - waterproof
Audio
Yes: two-way audio capability
5.4 cm x 5.4 cm x 10.2 cm
568 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Minimum Illumination
0 lux - B&W , 0.3 lux - colour
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 9 V
Alarm function, progressive scanning, image flip, image mirror, Motion Detection Technology, multi-streaming, Intelligent Video Analysis (IVA), Audio Detection, Motion Zone Alert, auto white balance, Wi-Fi Direct
Environmental Parameters (operating)
-10 °C - 50 °C; 0 - 90% relative humidity
Audio Support
Wired, wireless
5.4 cm
5.4 cm
10.2 cm
568 g
Camera
Colour - Day&Night - fixed - outdoor - waterproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
15 m
Video Capture
1920 x 1080 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
2 MP CMOS 1/2.8"
Effective Pixels
1944 x 1224
Lens Construction
Fixed focal
Focal Length
2.8 mm
Horizontal Field of View (degree)
111
Vertical Field of View (degree)
62
Network Interface
Network Protocols
DHCP, DNS, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, UPnP, IPv4, Bonjour, RTCP, SSL, SNTP
Ports
LAN - RJ-45 , Audio line out , Audio line-in/microphone
Supported Memory Cards
microSD Card, microSDHC Card
Mounting kit
1 x network cable - external
IP66
White
Power Requirements
DC 9 V - 1 A
Power adapter 9 Watt
Apple MacOS X 10.7 or later, Android 4.x, Microsoft Windows XP / 7 / 8 or later, Apple iOS 6.x or later
-10 °C
50 °C
Relative Humidity (operating)
0 - 90%
