Make the most of your time and space with a versatile 4-in-1 multifunction fax machine. The Samsung SF-760P laser fax offers fax, print, scan and copy functionality in a single efficient device. Advanced fax features like speed dialling and group dialling allow more powerful and easier communication, while Delay Send Mode helps you to save by automatically sending faxes outside peak hours. You'll take the hassle out of printer administration, too, with integrated Easy Printer Manager software to monitor and control print functions. Make your job easier with a multifunction fax that works harder.
Simple and efficient printer management made easy
Discover simplified print management with Easy Printer Manager. This integrated EPM software allows you to quickly set up your device and monitor status using only simple-to-use software. Never worry about unexpectedly running out of toner again, as toner ordering, device discovery, application linking and other functions are all easily accessible withEasy Printer Manager. -
Unleash your workforce with 4-in-1 functionality
With 4-in-1 versatility, the Samsung SF-760P laser fax streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy, scan and fax functionality, the SF-760P offers flexibility and lets you work with less barriers. A host of innovative features ensure that your workforce has the necessary functionality needed to thrive in the modern world of business. -
Achieve more with Samsung's Fast Print & High speed fax
With Samsung's faster printing speed of 20 pages per minute, you can minimise time wasted hanging around the printer. The enhanced printer performance will streamline workflows and let employees, and businesses, reach their full potential. A 33.6Kbps modem speed makes for fast communication and enhanced efficiency. What's more, 8MB of memory on both models means that you can store up to 600 pages of information. -
Delay Send Mode saves on call charges
The Delay Send button on the control panel stores documents in the memory, and allows you to send them during a predefined time period when off-peak call charges apply – allowing you to make significant savings on your phone bill. -
Taking the hassle out of faxing
The Samsung SF-760P is designed to deliver fast and efficient fax communication. The controls include 20 assignable instant dialing buttons, and you can store as many as 200 frequently used numbers for speed dialing. When you need to send documents to multiple locations you can use the SF-760P to store up to 209 contacts, in up to 100 separate groups or lists for group dialing. An additional 9 contact numbers can also be stored in the memory and all of the contacts can receive the same fax message by using the machine's Multi Send feature. Now you can send numerous fax messages to numerous contacts as often as you like! Once again Samsung simplifies your complex life with a fax machine that is quick, easy, and efficient.
- Samsung SF 760P - Laser Fax ( B/W )
- Fax
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser ( monochrome )
- Monthly Duty Cycle (max)
- 10000 impressions
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 20 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- PC Connection Availability
- PC Connection
- USB 2.0
- 42.6 cm x 26 cm x 28 cm
- 6.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax / copier / printer / scanner
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 impressions
- Display
- 2 lines x 16 characters
- Standard Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Collation copy
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- SPL
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- Total Memory Capacity
- Up to 600 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Fax forwarding, automatic redialing, priority transmission, multi-send, delayed sending
Document & Media Handling
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 20 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
- 150 sheets
- 100 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Output tray - 100 sheets - Legal (216 x 356 mm) , ADF - 20 sheets - 216 x 356 mm
- Speed Details
- Printing : up to 20 ppm ( A4 ) - B/W , Printing : up to 21 ppm ( Letter A ) - B/W , Copying : up to 20 ppm ( A4 ) - B/W , Copying : up to 21 ppm ( Letter A ) - B/W
PC Connectivity
- PC Connection
- USB 2.0
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 10.2, openSUSE 10.3, openSUSE 11.0, openSUSE 11.1, Ubuntu Linux 7.10, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows Vista, Red Hat Fedora Core 5, MS Windows Server 2008, openSUSE 11.2, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Fedora 13, Debian Linux 5.0, Apple Mac OS X 10.4 - 10.7
- 310 Watt
- Power Consumption Standby
- 30 Watt
- Power Consumption Sleep
- 2.3 Watt
- First Copy Out Time B/W
- 15 sec
- Consumables Included
- 1 x Cartridge ( black ) - up to 700 pages - Samsung MLT-D101S
- Supported Windows 7 Features
- Windows HD Imaging
- ISO/IEC 19752
- 42.6 cm
- 26 cm
- 28 cm
- 6.3 kg
- Sound Emission
- 26 dBA (idle) / 50 dBA (operating)
