HP LaserJet Enterprise M554dn Printer
Quicklinx: GGKWWS00 Mfr#: 7ZU81A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
10 In Stock
£531.86 ex VAT
£638.23 inc VAT
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
HP LaserJet Enterprise M554dn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
Number of Users
5-15 users
27.5 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ipm - duplex - A4 (210 x 297 mm) , Up to 35 ipm - duplex - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - A4 (210 x 297 mm) , Up to 35 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 4.6 ppm - black portrait - A5 (148 x 210 mm) , Up to 4.6 ppm - colour - A5 (148 x 210 mm) , Up to 55 ppm - black landscape - A5 (148 x 210 mm) , Up to 55 ppm - colour - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
(1 GB)
Flash Memory Installed (Max)
4 GB
Language Simulation
PCL 5C, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, opaque film, paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 - 8500 pages
Print server
Printer Features
Hardware integration pocket, PANTONE calibrated, Instant-on Technology, Mopria certified, Auto Power On, Auto Power Off
UNIX, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), openSUSE 12.2, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Microsoft Windows RT 8.1, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Microsoft Windows RT 8, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x
Environmental Standards
EPEAT Silver
1-year warranty
45.8 cm x 47.9 cm x 40 cm
Printer Type
Number of Users
5-15 users
Printer
Print Speed
Built-in Devices
2.7 inch QVGA LCD display, 24-key pad
Preview Screen Size
2.7"
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
HP ImageREt 3600
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
1 GB (max)
Flash Memory
Flash Memory
4 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
Bypass tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray: 1 x automatic - 550 sheets - 216 x 297 mm weight: 60 g/m² - 220 g/m² , Output tray: automatic - 250 sheets
Max Media Capacity
1200 sheets
Output Trays Capacity
250 sheets
Duty Cycle
80000 pages
2000 - 8500 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, LDAP, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 5500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 3500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 3500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 3500 pages ISO/IEC 19798 , 1 x waste toner collector
FCC Class A certified, CISPR 22 Class A, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EN 55022:2010 Class A, ICES-003 issue 5 Class A, IEC 62479:2010, EN 60825-1:2007, FCC CFR47 Part 15 A
Power supply - internal
589 watt
Power Consumption Stand by
28.5 watt
Power Consumption Sleep
2.17 watt
Software Included
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
Blue Angel
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
15 °C
30 °C
10 - 80%
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
51 dBA
45.8 cm
47.9 cm
40 cm
27.5 kg
Width (Shipping)
60 cm
Depth (Shipping)
50 cm
Height (Shipping)
59.8 cm
Weight (Shipping)
31.3 kg
Ink (4)
GGKW HP M522 Laserjet Toner Collection Unit In Stock £19.53
GGKW HP M522 220V Fuser Unit In Stock £211.35
GGKW HP 212X High Yield Yellow Original LaserJet Toner Cartridge In Stock £291.18
GGKW HP 212X High Yield Black Original LaserJet Toner Cartridge In Stock £206.22
Other bundles (2)
GGKW HP Care Pack Next Business Day Hardware Support with Defective Media Retention 3 Years On-Site In Stock £157.43
GGKW HP Color LaserJet Printer Cabinet For Color LaserJet Enterprise In Stock £208.95
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: £500 - £750
