Samsung SCX4729FW 4-in-1 Wireless MFP Mono Laser Printer - Print, Scan, Fax & Copy
Quicklinx: 7R92WS00 Mfr#: SCX-4729FW/SEE
If you're looking for a versatile print solution that offers high performance, financial savings and eco-friendliness, choose the Samsung SCX-4729FW Mono Laser Multifunction Printer. You can print, scan, copy and fax without needing several costly and space-intensive devices. Fast Speed printing makes sure your demands are met, thanks to the fast 533MHz processor and 128MB of memory. Duplex printing capabilities allow you access to a diverse range of single and double-sided formats that can reduce your paper costs and environmental impact. You can also make eco and cost savings with Eco Mode, activated quickly with the convenient Eco Button, which optimises usage of energy and supplies.
  • No strings attached
    Turn your computer loose with wireless printing. There are no more cables tripping you up and no need to plug and unplug machines to identify the right printer. And better yet, a wireless printer can be shared by many computers, saving you money on hardware and energy costs. Break free from the restraints of cables and say goodbye to cable clutter with the SCX-4729FW wireless laser printer.
  • It multi-tasks so you don't have to
    Productivity is a key to running any office or professional workgroup. The ultra-versatile, fast-printing SCX-4729FW is designed to deliver productivity. Now you can print, copy, scan and fax with convenience, ease and speed. Why clutter a corner of your office with several different machines when all you need is one versatile device – the 4-in-1 SCX-4729FW laser multifunction printer.
  • Work better with Fast Speed printing performance
    Print documents (small or large) quickly thanks to Samsung's Fast Speed printing, which is made possible with the 533MHz CPU and 128MB memory. Perfect for getting important work documents printed with high quality and zero fuss, the faster printing speeds will also help boost office productivity and enhance workflows. A reliable and superior printer like this will quickly become a must-have business tool - you'll wonder how your business ever functioned without one.
  • Being eco-friendly just got easier
    Make hitting your environmental goals a whole lot easier with Samsung's new Eco Mode, which also includes a Results Simulator to check how well you are doing. The Eco Mode features a one touch Eco Button, which conveniently serves as your default setting once activated, and reduces paper consumption with Duplex printing, 2 or 4-up printing and a Toner Save setting. Thanks to the Results Simulator, you can really appreciate how much good work you are doing. The simulation shows levels of carbon dioxide emissions, electricity and paper usage. The Eco Mode is an easy and effective way of keeping track of your printer consumption – which is better for you and the planet!
  • Get more from every page with Duplex printing
    Double your print output. Or, halve your paper costs. Either way you look at it‡ there is no denying that Duplex printing is an essential feature for both business and personal printing. It provides loads of cool and creative ways to fulfill print jobs, from single-sided formats to double-sided booklet formats, and really delivers a professional look and feel every time. The double-sided printing capabilities will also massively reduce costs and ensure that your paper supplies last longer. This then helps reduce waste, and minimises your impact on the environment. So, it is definitely a win-win situation with Duplex printing.
Samsung SCX-4729FW - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
12000 impressions
Max Copying Speed
Up to 28 ppm
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, recycled paper, thin paper
Standard Media Capacity
250 sheets
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
40.6 cm x 33.8 cm x 38.4 cm
11.1 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
12000 impressions
Display
2 lines
Standard Memory
128 MB 128 MB
Copying
Max Copying Speed
Up to 28 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, fit to page, Poster Copy, Clone Copy, collation copy
Printing
Max Printing Speed
Up to 28 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, SPL
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi
Total Memory Capacity
Up to 600 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Broadcast Transmission
209 stations
Delayed Transmission
Fax forwarding, automatic redialing, auto reduction, last number redial, multi-send
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
40 sheets
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), 76 x 127 mm, Oficio (216 x 343 mm)
250 sheets
120 sheets
Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 40 sheets size: 142 x 148 mm - 216 x 356 mm , Output tray - 120 sheets
Speed Details
Printing: up to 29 ppm (Letter A) , Copying: up to 29 ppm (Letter A) , Printing: up to 28 ppm (A4) , Copying: up to 28 ppm (A4)
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.4 - 10.6, MS Windows Vista, MS Windows Server 2008
First Copy Out Time B/W
15 sec
40.6 cm
33.8 cm
38.4 cm
11.1 kg
Sound Emission
26 dB (idle) / 52 dB (operating)
