Samsung printers are compactly designed, offering a stylish look that's compatible with all small office and home office working environments. This robust and durable model is reliable even in the most intensive office environments. Low noise levels are an added advantage with reduced interference and vibration in your workplace, therefore avoiding any unnecessary distractions.
This device uses enclosed 250-sheet paper input cassettes that reduce user intervention and the need to frequently replenish paper. Selecting Toner Save Mode allows you to use less toner on each page. This extends toner cartridge life by up to 30%, reduces your cost-per-page, lowers user intervention and helps to meet environmental standards.
Not only does the ultra-versatile SCX-4623FW let you print, scan, copy, and fax, it connects you to your wireless network with its one-touch Wi-Fi setting button.
Capture what catches your eye
Samsung's AnyWeb Print software lets you go hunting and gathering on the Web. You can utilise the SCX-4623FW to easily select, drag and drop content from different web pages onto a printable scrap board in your browser window, all while you surf. It's the easy way to collect, arrange and edit those useful reference points and resources you can only find on the Internet for that big project – or just for fun. -
No strings attached
Turn your computer loose with wireless printing. There are no more cables tripping you up or plugging and unplugging machines to identify the right printer. And better yet, a wireless printer can be shared by many computers, saving you money on hardware and energy costs. Break free from the restraints of cables with the SCX-4623FW laser printer. -
Setup is a cinch withsecure, one-touch wireless connection
The SCX-4623FW's Wi-Fi Protected Setup button lets you connect quickly and easily. Simply select the WPS button on the access point (router), press the WPS button on the printer and you're done. Normally, you would have to spend time creating a wireless network name and manually entering a security key or password on all the wireless devices. But the ultra-convenient WPS button automatically configures - and protects - your wireless network for you. -
It turns your PC into a fax machine
From lunch specials to important documents, the SCX-4623FW makes sending and receiving faxes a cinch. It can deliver and save received fax data in a folder on your PC as well as change document files to image files so you can send faxes from your desk – saving toner, paper and energy. Now that's efficiency. -
It multi-tasks so you don't have to
Productivity is key to running any office or professional workgroup. And the versatile SCX-4623FW was designed to deliver exactly that. Now you can print, copy, scan, fax and PC-fax with unparalleled convenience, ease and speed. Why cram a corner of your office with several different machines when all you need is one central device – the 4-in-1 SCX-4623FW laser multifunction printer.
- Samsung SCX-4623FW - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 12000 impressions
- Max Copying Speed
- Up to 22 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 22 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 80 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi
- 41.6 cm x 40.9 cm x 27.6 cm
- 14.8 kg
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 12000 impressions
- Display
- 2 lines x 16 characters
- Interface
- Standard Memory
- 128 MB 128 MB
Copying
- Max Copying Speed
- Up to 22 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Up to 22 ppm
- Printer Drivers / Emulations
- SPL
- First Print Out Time B/W
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 225 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Delayed Transmission
Document & Media Handling
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 40 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 80 sheets
- Paper cassette - 250 sheets , Output tray - 80 sheets , ADF - 40 sheets - 216 x 356 mm
- Speed Details
- Copying: up to 22 ppm (A4) , Printing: up to 22 ppm (A4)
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, Apple Mac OS X 10.3 - 10.6, MS Windows Vista, MS Windows Server 2008
- First Copy Out Time B/W
- 15 sec
- Consumables Included
- 1 x toner cartridge (black)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Limited warranty - parts and labour - 1 year - on-site
- 41.6 cm
- 40.9 cm
- 27.6 cm
- 14.8 kg
- Sound Emission
- 50 dB (operating)
