Samsung QM43R 43" 3480x2160 HDMI LED Large Format Display
Quicklinx: F9RVWS00 Mfr#: LH43QMREBGCXEN
Samsung's QMR series displays cut through the clutter to deliver advanced UHD resolution as well as intelligent UHD upscaling and rich flawless colors with Dynamic Crystal Color all in a slim design.
  • Incredible 4K picture quality
    Samsung's QMR series provides ultra-high-definition 4K resolution, creating lifelike images with sharper picture quality than ever before.
  • Intelligent UHD upscaling
    Samsung's intelligent UHD upscaling technology performs edge restoration and noise reduction to deliver perfect UHD picture quality even with lower resolution content. This "future-proof" solution ensures high picture quality regardless of the original content resolution.
  • Dynamic Crystal Color
    The QMR series features Dynamic Crystal Color, using 10 bit processing for flawless color expression, allowing viewers to enjoy a wider spectrum of colors up to one billion shades. HDR+ functionality converts standard definition content to HDR quality for sharper contrast and more vivid colors.
  • Perfect view with non-glare display
    The QMR series features reliable, non-glare panels that provide better visibility from all angles, anytime of day allowing businesses to deliver accurate information 24/7 in locations where clear and accurate information is crucial such as airports and commuter stations.
  • Slim and symmetrical design
    The QMR series features an innovative symmetric design simplifying wall mounting and ensuring installation is seamless. The flat back and slim depth will ensure a display that will stand the test of time.
  • Clean cable management
    With QMR's cable guide feature, retailers are able to tuck away messy cables from view. This allows for a clean and visually-appealing shopping experience for customers, even when the back of the display is visible.
  • Powerful, all-in-one solution
    SSSP is an all-in-one solution that simplifies installation and maintenance. With Tizen 4.0, businesses can enjoy easy development, reinforced capability with multiple web formats and standards and secured protection.
  • Wi-Fi and Bluetooth built-in
    Built-in Wi-Fi and Bluetooth allow for more personalized and interactive services as well as simplifying how businesses showcase content. Whether it's to make networking simpler or enabling interactive beacon technology in-store, QMR series displays help businesses move into the future of retail.
Samsung QM43R QMR Series - 43" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
43"
Commercial Use
Yes - digital signage
Platform
Tizen OS 4.0
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Format
HDR10+
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, Bluetooth
PC Interface
DVI, DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Picture Enhancements
Mega Dynamic Contrast Ratio, UHD Upscaling, Dynamic Crystal Color
USB
2 ports
Voltage
Energy Class
Class G
110 Watt
Power Consumption (On mode)
74 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
108 kWh
96.75 cm x 4.83 cm x 55.77 cm
10 kg
Energy Class
Class G
110 Watt
74 W
74 kWh/1000h
108 kWh
Diagonal Class
43"
Commercial Use
Series
QMR Series
Platform
Tizen OS 4.0
HDR Capable
HDR Format
HDR10+
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Design
Narrow Bezel Design, Slim Design, New Edge Design
Dimensions
Without stand
96.75 cm
4.83 cm
55.77 cm
10 kg
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Coating
Anti-glare, 0.44% Glass Haze
Image Contrast Ratio
4000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
MagicInfo, Daisy Chain
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
2
Network & Internet Multimedia
Connector Type
2 x HDMI input , DisplayPort input , DVI-Digital , 2 x USB , Audio line-in , Audio line-out , RS-232 input , RS-232 output , LAN , Infrared input
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, NEMKO, NOM, SASO, CB, FCC Part 15 B, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, EN 60950-1, KC, AS/NZS, NOM-019-SCFI-1998, K60950-1, cUL No.60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, IS13252, GB 17625.1-2012, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, KN32, KN35, KCC/EK, CNS 14336-1, CISPR 32:2015, RoHS CNS 15663, CISPR 32:2016, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
109.5 cm
Depth (Shipping)
15.1 cm
Height (Shipping)
67.6 cm
Weight (Shipping)
13.3 kg
10 - 80% (non-condensing)
