Samsung's SMART ProXpress M4580FX monochrome multifunction printer provides smart usability that allows users to work fast and efficiently with intuitive, easy-to-use controls, high performance and resource-efficient features.
Enjoy preloaded applications and widgets
It’s all about convenience and flow. Your favorite applications such as Copy, Scan / Send, Box, Job Status, Address Book and Help come preloaded while custom widgets provide instant access to frequently used functions. -
Stand out with sharp, high-quality print output
Samsung’s unique Rendering Engine for Clean Page (ReCP) technology delivers sharper text and cleaner images. A superior resolution of 1200 x 1200 effective dpi ensures that everything you do will stand out. -
Touch to print, just like on a tablet
Innovation and usability is built into the SMART ProXpress M4580FX. The Samsung SMART UX Center is the first smart Android printing UX that is intuitive, extendible and ensures compatibility with various Android-based devices. -
Faster scanning and fuss-free printing
The SMART ProXpress M4580FX is equipped with Dual-Scan ADF technology that delivers faster scanning speeds of up to 35 single-sided image per minute (ipm) and a 1 GHz dual-core CPU that powers printing at 45 pages per minute (ppm). With high-performance speed printing, businesses can work smoothly and operate more efficiently. -
Save resources with low TCO printing
Reduce labor costs for heavy printing with ultra-high-yield toner cartridges and drums. Toners that yield 30000 standard B&W pages and drums that yield 100000 will lower your TCO and reduce waste. -
eXtensible open architecture (XOA)
The XOA web platform supports an array of server-based productivity solutions. From the UI, users can tap into a robust lineup of web-connected solutions. From the server, printer network managers can easily install and manage custom solutions tailored for your business. -
SMART Manage
Enhance the UI by arranging and managing the environment by user with My Page. Simply customize the My Page settings and Quick Menu for each user and you can keep track of an individual’s usage, control accessibility and more. Administrators can also create quick custom apps directly on the devices.
- Samsung ProXpress M4580FX - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 2000 - 10000 pages
- Max Copying Speed
- Up to 35 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 600 x 600 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 10.1"
- Original Size
- 105 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock, cotton paper, punched paper, preprinted paper, archive paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network, Business Core Printing Solutions (BCPS), Samsung SMART UX Centre, XOA (eXtensible Open Architecture) Web Platform
- 53 cm x 45.95 cm x 64.9 cm
- 30.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 200000 pages
- Display Diagonal Size
- 10.1"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 35 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Image Repeat, Poster Copy, Edge Erase, proof copy, mirror image
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.7
- First Print Out Time B/W
- 6.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Broadcast Transmission
- 500 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, on hook dial, last number redial
Document & Media Handling
- Min Original Size
- 105 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 500 sheets
- Paper cassette - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets , ADF - 50 sheets size: 105 x 148 mm - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 45 ppm (A4) - B/W , Printing: up to 47 ppm (Letter A) - B/W , Copying: up to 35 ppm (A4) - B/W , Copying: up to 36 ppm (Letter A) - B/W , Scanning: up to 60 ipm - B/W duplex , Scanning: up to 35 ipm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Secure Print
- Operating System Support
- MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Android, Apple Mac OS X 10.5 - 10.9
- 900 Watt
- Power Consumption Sleep
- 1.8 Watt
- First Copy Out Time B/W
- 6.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 7000 pages
- ENERGY STAR Certified
- 53 cm
- 45.95 cm
- 64.9 cm
- 30.2 kg
- Sound Emission
- 30 dBA (idle) / 56 dBA (operating)
