Draw more visitors to your retail business by effectively delivering promotional messaging with excellent visibility. OMD series SMART Signage features high brightness and contrast ratio for superb visibility in various lighting environments. Even customers who are wearing polarized sunglasses can view messages with outstanding clarity and brightness, without the display-blindness effect typically experienced with LCD displays.
- Samsung OM75D-W 75" LED display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Wall Components Qty
- 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- S-PVA
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock
- Speaker System
- 2 speakers
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 935 Watt
- Power Consumption (On mode)
- 542 W
- Energy Consumption per Year
- 791 kWh
- Dimensions (WxDxH) - without stand
- 167.58 cm x 12.46 cm x 95.38 cm
- 48 kg
- Product Type
- Energy Class
- Class D
- 935 Watt
- 542 W
- 791 kWh
- Diagonal Class
- 75"
- Commercial Use
- TV Tuner
- No tuner
- Sensors
- Temperature sensor, brightness sensor
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode
- 100
- Dimensions
- Without stand
- 167.58 cm
- 12.46 cm
- 95.38 cm
- 48 kg
Display
- LCD Display Technology
- S-PVA
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 5000:1
- Brightness
- 2500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6 ms
- Button lock
- Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo, anti-image retention, Smart Scheduling, MagicInfo Player-S2
Stands & Mounts
- Flat Panel Mount Interface
- 900 x 600 mm
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , DisplayPort input , 2 x HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
- Cables Included
- VGA cable
- Plug and Play, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, EN 60950-1, KCC, BSMI CNS 13438, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, GB4943.1-2011, GB 17625.1-2012, IEC60950-1
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 181.5 cm
- Depth (Shipping)
- 41.5 cm
- Height (Shipping)
- 107.5 cm
- Weight (Shipping)
- 60 kg
- 0 °C
- 30 °C
- 10 - 80%
