Samsung OH85F 85" 1920x1080 HDMI LED Large Format Display
Quicklinx: F9S5WS00 Mfr#: LH85OHFPLBC/EN
Samsung's OHF Series comes complete with an advanced cooling system with heat exchanger, supported by advanced thermal control functionality. This enhances the overall efficiency in terms of both management and cost through its filter-less system. The system revolutionizes outdoor signage design, abandoning the thick enclosures to accommodate a full display package.
OHF Series displays feature innovative Magic Glass, TUV Certified Image Quality and an Auto Brightness Sensor to optimize brightness in order to optimally convey messaging to virtually any viewer. These powerful displays also feature circular polarizing technology that eliminates display blindness caused by polarized sunglasses. OHF Series captivate viewers with superior messaging clarity delivered with high 2,500 nit brightness and 5,000:1 high contrast ratio in all inches above 24.
  • Possessing a self-cooling system with no need for filter or maintenance
  • High visibility
  • Reflection prevention
    Greater content visibility is achieved under a combination of high brightness, lower reflection and high contrast ratio. The Magic Glass of the OHF Series that is in front of the displays' LCD panels removes the protection glass reflection, making the displayed images richer and clearer under direct sunlight.
Samsung OH85F OHF Series - 85" LED-backlit LCD display - 4K - outdoor - for digital signage
LED-backlit LCD flat panel display - outdoor
Diagonal Class
85"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
S-VA
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Auto Source Switching & Recovery, Lamp Error Detection
USB
Remote control, batteries
Voltage
Energy Class
Class D
Power Consumption (On mode)
680 W
Energy Consumption per Year
993 kWh
200.4 cm x 12 cm x 118.5 cm
172 kg
Energy Class
Class D
680 W
993 kWh
Diagonal Class
85"
Commercial Use
Series
OHF Series
Outdoor
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, brightness sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode, landscape mode
Protection
Tempered glass protection
200.4 cm
12 cm
118.5 cm
172 kg
Display
LCD Display Technology
S-VA
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Dynamic Contrast Ratio
100000:1
Brightness
2500 cd/m²
Commercial Features
Multiple Display Control (MDC), Auto Brightness Control, support 3G via dongle
Stands & Mounts
Flat Panel Mount Interface
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Network & Internet Multimedia
LAN
Connector Type
2 x HDMI , USB , RGB input , Audio line-out , Serial input , Serial output , 2 x LAN
Batteries
UL, IEC 60950-1, EN 60950-1, IK10, FCC Part 15 B Class A, cUL No.60950-1, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
-30 °C
50 °C
10 - 80% (non-condensing)
