Samsung's SMART ProXpress X4300LX color multifunction printer provides smart usability that allows users to work fast and efficiently with intuitive, easy-to-use controls, high performance and resource-efficient features.
SMART touch
Touch to print, just like on a tablet. With the Samsung SMART UI Center, you'll get intuitiveness, usability and extendibility at the same time, for perfect compatibility with various Android-based smart devices. Samsung SMART UI Center is a pioneering printing UI based on the Android OS. -
Preloaded applications and widgets
Printing applications are preloaded, including Copy, Scan/Send, Box, Job Status, Counter, Settings, Build Job, Address Book and Help, which provide users with more convenient usability. Plus, there are custom widgets for creating instant, one-tap access to frequently used functions. -
SMART use
The Real Preview Function is available in preloaded applications such as Copy, Send and Box. You can further extend usability with direct web access through the web browser to quickly print various web contents, such as maps, pictures, emails and more without a PC. -
SMART manage
Enhance the UI by arranging and managing the environment by user with My Page. Simply customize the My Page settings and Quick Menu for each user and you can keep track of an individual's usage, control accessibility and more. Administrators can also create quick custom apps directly on the devices. -
High scan rate and fast print processing
Dual-Scan ADF technology delivers scanning speeds of up to 80 single-sided images per minute (ipm), up to 100 double-sided ipm for color and up to 120 double-sided ipm for mono. This workhorse MFP also prints up to 30 pages per minute (ppm). A 1 GHz dual-core CPU provides the power and capacity to swiftly accomplish various print and copy jobs. -
High-quality print output
Samsung's unique Rendering Engine for Clean Page (ReCP) technology automatically sharpens the focus of both graphics and text to deliver sharp, clean output. With an exceptional resolution of 1,200 x 1,200 effective dpi, your scans, printouts and company will always look professional. -
Low TCO printing
Handle heavy printing volumes while maximizing resource-efficiency and reducing labor costs with ultra-high-yield toner cartridges and drums. Flexible options range from toners that yield 30,000 standard black and white pages, as well as a drum that yields 100,000 pages. -
eXtensible open architecture (XOA)
The XOA web platform supports an array of server-based productivity solutions. From the UI, users can tap into a robust lineup of web-connected solutions. From the server, printer network managers can easily install and manage custom solutions tailored for your business. Learn More -
Tailor-made MFPs
Meet specific needs with various configuration capabilities. Factory-provided modules serve as a basis upon which different components are chosen, and a wide array of optional components can be added, including a wireless and NFC option, up to three extra paper cassettes, memory expansion and a stand.
- Samsung MultiXpress X4300LX - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 7000 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 10.1"
- Original Size
- A3 (297 x 420 mm), Ledger (279 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 148 mm (min) - 297 x 432 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, thin paper, thick paper, card stock, extra heavy-weight paper, glossy paper, cotton paper, punched paper, preprinted paper, archive paper
- Standard Media Capacity
- 1140 sheets
- Max Media Capacity
- 2180 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, Rendering Engine for Clean Page (RECP) technology, Business Core Printing Solutions (BCPS), Samsung SMART UX Centre
- 56.6 cm x 61 cm x 87.9 cm
- 80 kg
- Laser - colour
- 120000 pages
- 7000 pages
- Display Diagonal Size
- 10.1"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 2 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Image Repeat, Poster Copy, Job Build
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF, PCL 5ce
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 11.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 297 x 432 mm, 148.5 x 210 mm, 297 x 354 mm
- 1140 sheets
- 2180 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets - A3/Ledger (297 x 432 mm) weight: 42 g/m² - 163 g/m² , 2 x paper cassette - 520 sheets size: 98 x 148 mm - 297 x 354 mm weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - 297 x 432 mm weight: 60 g/m² - 176 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 30 ppm (Letter A) - B/W , Printing: up to 30 ppm (Letter A) - colour , Copying: up to 30 ppm (A4) - B/W , Copying: up to 30 ppm (A4) - colour , Copying: up to 30 ppm (Letter A) - B/W , Copying: up to 30 ppm (Letter A) - colour , Scanning: up to 80 ipm - B/W , Scanning: up to 120 ipm - B/W duplex , Scanning: up to 80 ipm - colour , Scanning: up to 100 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, SSL, TLS, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- HP-UX 11i v3, IBM AIX 5.1, IBM AIX 5.2, Sun Solaris 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, HP-UX 11.0, HP-UX 11i v2, Sun Solaris 10, IBM AIX 5.3, IBM AIX 6.1, openSUSE 11.2, openSUSE 11.3, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Ubuntu Linux 10.10, openSUSE 11.4, Debian Linux 5.0, Red Hat Enterprise Linux 5, IBM AIX 7.1, HP-UX 11i v1, Red Hat Enterprise Linux 6, Ubuntu Linux 11.04, Fedora 15, Debian Linux 6.0, Ubuntu Linux 11.10, Ubuntu Linux 12.04, IBM AIX 5.4, openSUSE 12.1, MS Windows Server 2012, Windows 8, Windows 8 64-bit, Fedora 16, Fedora 17, MS Windows Server 2012 x64 Edition, Android, Fedora 18, openSUSE 12.2, openSUSE 12.3, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.0, Debian Linux 7.1, Linux Mint 15, Sun Solaris 11
- 1.2 kW
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 5.9 sec
- First Copy Out Time Colour
- 7.6 sec
- 56.6 cm
- 61 cm
- 87.9 cm
- 80 kg
- Sound Emission
- 30 dBA (idle) / 54 dBA (operating)
