Achieve more in your workday with Samsung's easy-to-use ML-6510ND printer. Matching high-quality print performance with amazingly low running costs, this durable monochrome laser printer is perfect for any business. Features such as anti-jam technology, a Gigabit Network, 700MHz Dual-core CPU, and a new handy Replaceable Maintenance Kit will ensure that your document workflow is smooth and always driving office productivity. Its user-friendly features such as the user panel, with numeric keypad and one-touch convenience (eco button), the Easy Print Manager and Secure Printing are suited for any modern office environment. With the heavy media handling capabilities (with full range of paper input / output options), the busier times won't seem so stressful. So, don't settle for anything less than a high-performing printer that's also big on convenience.
Take control of office documents with Secure Printing
Important documents can easily end up in the wrong hands, especially when work printers are shared among many users. With Secure Printing you can now keep your documents safe from prying eyes using a pin code, which prevents your documents from being printed until it has been entered. Once you have sent the job to the printer, you simply go to the printer, scroll down the user interface to find your particular file, and then authorise the print by entering in the pin code. This is a simple and effective way of keeping tight control over the circulation of important documents, while also minimising unnecessary printing. -
Streamline productivity withEasy-to-Use Features
Settle for nothing less than brilliant printing solutions that are trouble-free. The simple OP panel, which features a new compass dial, a 4-line LCD display and a numeric keypad, provides a simple and easy way to take full control of your printing operation. Featuring a new one-touch convenience eco button, which is easily found on the front panel and acts as a default setting once turned on, you can now combine two pages into one document. This helps you cut-back on costs by reducing paper and toner use, and therefore also lessens your impact on the environment. The OP panel also simplifies your workflow, with fewer buttons and unnecessary options to worry about. You can really produce amazing results in no time at all. -
Professional Operations with a Full Range of Finishing Options
With a full range of options for high volume printing, your Samsung printer is ready to make very light work of heavier jobs. Utilising a massive input capacity of 3660 sheets of paper, four additional loading trays and one High Capacity Feeder (HCF) for extra support, preparing for those bigger print-runs is all too easy. And thanks to an impressive 1000 page output capacity, a finisher and 4 bin mailbox option, you can be sure that your work will be delivered safely and looking utterly professional. So, if printing is an important part of your job, then trust Samsung's full range of print options to get it done right. -
Meet Demands Easily with Heavier Media Mandling
From everyday documents to important presentations, you always need to give your printing the handling it deserves. If you want to impress with not only high-quality results but also with the professional manner in which you complete the task, then your printer will need heavy media handling. When you combine the Main Tray (supports 220gsm), and the Optional Tray (supports 220gsm), your printing operation will easily handle even the heaviest of jobs. From specialty paper and thick stock to envelopes, which no longer requires its own special feeder and now feeds through the Main Tray... your printing will be trouble-free, cost-effective and a pure breeze. -
Faster Speed & Printing Performance
Print documents (small or large) quickly thanks to Samsung's Fast Speed printing. Perfect for getting important work documents printed with high quality and zero fuss, the faster printing speeds will also help boost office productivity and enhance workflows. A reliable and superior printer like this will quickly become a must-have business tool - you'll wonder how your business ever functioned without one.
- Samsung ML-6510ND - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 34.8 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 65 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- Samsung 700 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, XPS, EPSON, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper
- Total Media Capacity
- 620 sheets
- Media Handling
- 100-sheet multipurpose tray, 520-sheet input tray
- Monthly Duty Cycle (max)
- 275000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows 2000, Debian Linux, Red Hat Enterprise Linux WS, Red Hat Fedora Core 1, Red Hat Fedora Core 2, Red Hat Fedora Core 4, SuSE Linux 10.0, Red Hat Fedora Core 3, Red Hat Fedora Core 9, Red Hat Fedora Core 10, Ubuntu 8.10, Ubuntu 9.04, Ubuntu 6.06, SUSE Linux Enterprise Desktop 11, Apple MacOS X 10.3 - 10.6, SuSE Linux 10.1, SUSE Linux Enterprise Desktop 10, Red Hat Fedora Core 5, Mandriva Linux, Ubuntu 5.10, Red Hat Fedora Core 6, openSUSE 10.2, openSUSE 10.3, openSUSE 10.1, openSUSE 10.0, Red Hat Fedora Core 7, Red Hat Fedora Core 8, Ubuntu 5.04, Ubuntu 6.10, Ubuntu 8.04, Ubuntu 9.10, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Ubuntu 7.10, Microsoft Windows Server 2008 R2 x64 Edition, Ubuntu 7.04, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 46.4 cm x 54 cm x 42 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- First Print Out Time B/W
- 7.8 sec
- Media Handling
- Processor
- Samsung 700 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 620 sheets
- Media Feeders
- 1 x automatic - 520 sheets , 1 x manual - 100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 275000 pages
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black)
- Supported Windows 7 Features
- Windows HD Imaging
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities
- OS Required
- Sound Emission (Idle)
- 30 dB
- Sound Emission (Operating)
- 56 dB
- 46.4 cm
- 54 cm
- 42 cm
- 34.8 kg
- Width (Shipping)
- 70 cm
- Depth (Shipping)
- 62 cm
- Height (Shipping)
- 68 cm
