Samsung ML-3750ND PRINTER
Quicklinx: 800FWS00 Mfr#: ML-3750ND/SEE
Discover a printer that helps reduce supply expenses while giving higher output and productivity. The Samsung ML-2168 mono laser printer lets you use ultra-efficient high-yield toner, so you can print large documents without running out. You'll also reduce costs by optimising output for your needs and budget with One-touch Eco Button. Double-sided Duplex printing allows you to halve paper costs or print twice as much, too, and anti-jam technology reduces interruptions for a more productive workflow. Choose printing you can rely on - whatever your needs.
Boost productivity with longer lasting toner
Tailor your business operation to match your needs, and enjoy high-quality, economical printing. With ML-3750ND high yield toner cartridges, which can print up to 15000 pages, handling large company documents and publications is easy. Whether your office is big or small, the Samsung ML-3750ND printer will deliver thousands of beautiful pages affordably.
Save with just one touch
Optimise your printing in one simple step with Samsung's One-touch Eco Button. You can save on printing expenses when you quickly switch to Eco mode and conserve toner, paper and energy. There's no need to waste time changing settings or altering your documents with this useful feature, as one touch is all you need to configure your printer to deliver the most economical results
Use half the paper with Duplex printing
Double your print output, or halve your paper costs. Either way you look at it´s Duplex printing is an economical feature for both business and personal printing. Double-sided printing capabilities reduce costs and ensure that your paper supplies last longer. This reduces waste, and minimises your impact on the environment. So, Duplex printing is definitely a win-win situation.
Hassle-free printing
Free your workday from time-consuming and stress-causing printer stops. This Samsung printer offers anti-jam technology that utilises a roller with unique backward friction action used during the paper pickup process. Common problems that often add to stress, such as miss-feeding and multiple paper feeding from the cassette tray, are a thing of the past. Samsung´s anti-jam technology lets your printing operation continue hassle-free, efficiently, and reliably
Protect office documents with Secure Printing
Nobody wants Important documents to end up in the wrong hands, especially when work printers are shared among many users. By using Secure Printing you have a PIN to prevent your documents from being printed until you enter the number. This is a simple and effective way to retain tight control over the circulation of important documents, while also minimising unnecessary printing.
Work faster with High-Speed printing performance
Print documents quickly thanks to High-Speed printing, which is possible because of Samsung´s 533MHz processor printing technology and optimised PCL. Perfect for printing graphics at high resolution with zero fuss. This faster printing speed also helps boost office productivity and enhance workflows.
Gigabit connectivity increases productivity
Boost your print job throughput by using Samsung´s powerful Gigabit network connection. This enhanced connectivity will ensure that large print jobs sent from multiple users can be completed quickly, without any compromise in quality. When important work documents, like big presentations, need to be perfect and delivered on cue, the Gigabit network will help keep everybody happy
Handle more paper requirements with the available sizes, types, and weights.
From everyday documents to important presentations, you always need to give your print jobs the right paper. If you want to impress with high-quality results in a professional manner, then your printer will need numerous paper options. The Samsung ML-3750ND provides the ability to use specialty paper, thick stock, envelopes, cards and more! Your print job paper requirements can be easily met so your results can impress.
