Samsung ME40C 40" 1920x1080 8ms DVI-D HDMI DisplayPort E-LED System on Chip Large Format Display
Quicklinx: 8YKFWS00 Mfr#: LH40MECPLGC/EN
  • 1080p
An increasing number of organizations are using large format displays (LFDs) to display their business content and to differentiate their organization from competitors. Companies need displays that offer excellent image resolution but are lighter weight and take up minimal space. The Samsung MEC series LED LFD delivers superior LED technology in a slim display without increasing energy costs. Equipped with Samsung's powerful and exclusive SSSP technology and integrated display solution, MagicInfo Premium S player, the Samsung MEC series can deliver multiple types of content seamlessly. Watch your display management productivity go up as your total cost of ownership goes down with this all-in-one display.
  • Easy content creation
    Easily create multimedia and interactive content with pre-made templates and customize compelling messages using drag and drop and the intuitive user interface.
  • Easy and efficient content deployment
    Play content on multiple displays from a central PC, directly from internal storage or USB drive through simple Plug and Play.
  • An integrated solution to provide a digital signage experience
    The Samsung Smart Signage Platform (SSSP) is embedded within Samsung displays, providing the power of a dual-core CPU and a combination of media player and integrated display solution, MagicInfo Premium S player. The solution eliminates the need for additional PC modules while reducing installation and maintenance issues. Using the included MagicInfo Premium S player, businesses can create, schedule, and deploy content effortlessly. Multiple types of content can be streamed simultaneously and continuously courtesy of the dual-core CPU and 8 GB of storage, and a high performance video processor integrated on a single chip. Save more by paying less for a display integrated with a media player and premium management solution.
  • Project large-scale images with less energy consumption
    The Samsung MEC series is economical and gentle on the environment. The MEC Series' edge-type LED features LED lamps located on the sides of the panel. The lamps emit light on the display sides, resulting in a much thinner screen that requires fewer lamps than conventional panels. With fewer LED lamps, power consumption and heat emission are reduced and a slim, lightweight design can be achieved. With these improvements, a more enjoyable environment can be created for viewers in close proximity to the displays.
  • Enhance readability with extraordinary picture quality
    The Samsung MEC series delivers high-quality images without the distortion, blur or glare inherent in traditional projectors to provide productive, distraction-free presentations. An ultra-clear panel provides sharper, more detailed images and enhanced picture quality. The panel also reduces light scatter and reflection to enhance readability. An enhanced contrast ratio and high brightness support more attractive, vibrant displays with detailed images.
  • Greater display flexibility with image rotation
    The MEC series offers Image Rotation feature, enabling image orientation rotation from portrait to landscape for greater display flexibility.
Samsung ME40C 40" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with built-in PC
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock
Speaker System
2 speakers
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
Remote control
Voltage
Energy Class
Class C
110 Watt
Power Consumption (On mode)
90 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
131 kWh
92.21 cm x 2.99 cm x 53.94 cm
10.6 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
110 Watt
90 W
131 kWh
Diagonal Class
40"
Commercial Use
Combined With
Built-in PC
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
92.21 cm
2.99 cm
53.94 cm
10.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
5000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Button lock
Pivot, Multiple Display Control (MDC), Lamp Error Detection, digital daisy chain, MagicInfo Lite, Smart Scheduling
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
USB Port
USB Ports Qty
1
Configuration
ARM Cortex-A9 ( 1 GHz ) 4 GB
4 GB
Operating System
Linux
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
2 x HDMI input , Composite video / component video input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Multiple Display Control , USB 2.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in
VGA cable
EN55022, FCC Part 15 B
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
102 cm
Depth (Shipping)
13 cm
Height (Shipping)
61.6 cm
Weight (Shipping)
12.6 kg
10 - 80% (non-condensing)
