High productivity,cost-efficiency and versatility
Create professional documents more quickly
- High speed printing of up to 38 ppm (pages per minute).
- Higher-quality print output
- ReCP (Rendering engine for Clean Page) technology for sharp text and clear images.
- 1,200 x 1,200 effective dpi (dots per inch) resolution.
- Additional printing choices for professional documents
- A multipurpose tray that handles wide range of media, up to 220 gsm (grams per square meter), such as labels, cardstock and envelopes.
Reduce operating expenses with economical features and solutions
Professional eco solution
- Easy Eco Driver enables users to set options to remove unnecessary text or images and also change the layout such as N-up printing without changing the original documents before printing.
- One Touch Eco Button automatically activates 2-up (two pages on one side of the paper) and duplex printing, toner-save mode and the option to skip blank pages.
- More toner options, more choices for cost reduction**
- Diverse toner options from 3,000 to 10,000 page yields that meet every businesses' needs for reducing cost per page.
- An integrated toner system contains the imaging unit and toner cartridge in one convenient package. This integrated toner system is the preferred choice for businesses with a heavier printing volume who require a lower CPP and easier maintenance.
Central print usage control to save more resources
- Samsung SyncThruTM Admin solution enables management to assign users to specific devices, and assign predetermined quotas for the number of printed pages or copies by user.
Improve productivity with versatile features from duplex printing to security
- Built-in duplex printing
- Provides professional two-sided documents, brochures, and booklets with ease, which can also help save money and reduce paper use.
- Mobile printing, easier than ever
- Convenient mobile print, scan and fax with powerful compatibility, optimized for various business environments.
- Enterprise-level document security offers greater control of user, document and network access.
Streamline printing with ease-of-use design
- Easy Printer Manager for smooth print operation from toner and job ccounting to device settings.
- Easy secure printing with built-in numeric key pad.
- Easy connection through wireless printing without access point.
High speed printing
Robust ProXpress M3820 series features print speeds, powered by a Cortex-A5 core processor. High speed and performance enable businesses to accelerate document and image processing for increased efficiency. -
ReCP technology improves readability of printed documents by enhancing thin lines and sharpening the edges of negative text. The ProXpress M3820 series delivers sharp, solid prints with effective output print resolutions of up to 1200 x 1200 dpi. -
The printers' multipurpose tray supports media of up to 220-gsm (grams per square meter) in weight, which offers more printing choices for professional documents. Numerous labels, cards and envelopes can be printed using the multi-purpose tray with ease. This ability virtually eliminates the time it takes to feed sheets one at a time. -
One touch eco button
Businesses can lower toner and paper usage with the one touch eco button. The one touch eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides). Users can also choose the option to skip blank pages in the toner saving mode. -
Central print usage control, activated through the SyncThru admin job accounting feature, enables managers to assign users to specific printers. Users can also be assigned quotas for the number of pages or copies they can make per printer. -
More laser toner cartridge options, more choices for cost reduction
ProXpress M3820 series offers diverse laser toner cartridges options from standard-yield laser toner cartridges that typically yield 3,000 standard pages to ultra-high yield laser toner cartridges that can yield 15,000 standard pages, which meets every businesses' needs for reducing cost per page. An integrated toner system contains the imaging unit and toner cartridge in one convenient package. -
ProXpress M3820 series provides professional two-sided documents, brochures, and booklets with ease, which can also help save money and reduce paper use. -
Businesses produce and print numerous official documents including confidential information, which requires high security on the printing jobs. ProXpress M3820 series offers greater control of user, document and network access with Samsung SyncThru admin at the enterprise security level. -
ProXpress M3820 series features easy secure printing with built-in numeric key pad, which allows users to protect personal or confidential documents. When the feature is on, users are required to enter password in order to proceed the print job.
- Samsung ProXpress M3820ND - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 10.18 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (512 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, SPL (Samsung Printer Language), IBM ProPrinter, EPSON
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, cotton paper, bar code labels, thick paper, thin paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet paper cassette, 50-sheet bypass tray
- Monthly Duty Cycle (max)
- 80000 pages
- System Requirements
- UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8
- 36.6 cm x 36.56 cm x 26.25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 1200 dpi
- First Print Out Time B/W
- 6.5 sec
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 820 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- Power Device
- Power supply - internal
- 700 Watt
- Power Consumption Stand by
- 10 Watt
- Power Consumption Sleep
- 1.1 Watt
- OS Required
- Sound Emission (Idle)
- 26 dBA
- Sound Emission (Operating)
- 57 dBA
- 36.6 cm
- 36.56 cm
- 26.25 cm
- 10.18 kg
