The robust ProXpress M3320ND features print speeds of up to 35 ppm. Powered by a Cortex-A5 core processor and 128 MB of memory, it delivers unsurpassed performance for business applications. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency.
The ProXpress M3320ND features standard automatic duplex. Users can print on both sides of the page with ease, saving the company on costs, and reducing the impact on the environment.
High speed printing
The robust ProXpress M3320ND features print speeds of up to 35 ppm. Powered by a Cortex-A5 core processor, it delivers unsurpassed performance for business applications. High performance coupled with ease-of-use enables businesses to accelerate document and image processing for increased efficiency. -
Higher-quality print output
ReCP technology improves the readability of printed documents by enhancing thin lines and sharpening the edges of fine text. The ProXpress M3320ND delivers sharp, solid prints with effective output print resolutions of up to 1,200 x 1,200 dpi. -
Robust paper handling
The printers' multipurpose tray supports media of up to 58 pounds weight, which offers more printing choices for professional documents. Labels, cards, covers and envelopes can be printed using the multi-purpose tray with ease. This ability virtually eliminates the time it takes to feed sheets one at a time. -
Built-in duplex printing
The ProXpress M3320ND features standard automatic duplex. Users can print on both sides of the page with ease, saving the company on costs, and reducing the impact on the environment. -
One touch eco button
Businesses can lower toner and paper usage with the one touch eco button. The one touch eco button automatically activates 2-up printing (two pages on the same side) and duplex printing (printing on both sides), as well skipping blank pages and printing in toner save mode. The default eco settings can be adjusted using easy printer manager, and administrators can even enforce some or all of these rules in order to save your business money. -
Central print usage control to save more resources
Central print usage control, activated through the SyncThru admin job accounting feature, enables managers to assign users to specific printers, as well as assigning individual users or workgroups quotas. Tight usage controls as well as automatic notifications help business control costs and drive down spending. -
More laser toner cartridge options, more choices for cost reduction
The ProXpress M3320ND employs an all-in-one toner system, meaning that the toner and imaging unit are integrated into a single cartridge, for easy changing and easy stocking. It also both a standard-yield laser toner cartridges that typically yield 3,000 standard pages and a high yield laser toner cartridges that can yield up to 5,000 standard pages, which meets every business's needs for reducing spending. Whether you are looking for a lower up-front cost, or a lower overall cost per page, there's a cartridge suitable for your needs. -
Convenient mobile printing optimized for business
With the Samsung mobile print app, you and your employees can easily print from their mobile devices, at no additional cost. Users do not need to install a new driver or configure network settings. By simply downloading the Mobile Print app from the Google play store for Android or the App Store for iOS, and connecting to the Wi-Fi network on which the ProXpress M3320ND is shared, users can begin printing with ease. -
Easy printer manager
The easy printer manager helps companies remotely control settings, such as the one touch eco button, and easily access notifications and device status from one convenient location. Multiple devices can be monitored and managed using the easy printer manager. Businesses can also monitor printer status, such as error messages, including paper empty, toner empty and paper jam alerts.
- Samsung ProXpress M3320ND - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.86 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (128 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, SPL (Samsung Printer Language), IBM ProPrinter, EPSON
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, recycled paper, cotton paper, bar code labels, thick paper, thin paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet paper cassette, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- System Requirements
- UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Apple MacOS X 10.5 - 10.8
- 36.6 cm x 36.56 cm x 26.25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 1200 dpi
- First Print Out Time B/W
- 6.5 sec
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 128 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) , 1 x automatic - 1 sheet - Legal (216 x 356 mm)
- Max Media Capacity
- 771 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- Power Device
- Power supply - internal
- 700 Watt
- Power Consumption Stand by
- 10 Watt
- Power Consumption Sleep
- 1.1 Watt
- OS Required
- Sound Emission (Idle)
- 26 dBA
- Sound Emission (Operating)
- 55 dBA
- 36.6 cm
- 36.56 cm
- 26.25 cm
- 9.86 kg
