Powerful, affordable, and simple to use
Reduce print costs but don't settle for less than the best. An efficient Samsung Xpress M2875FD Series gives you the speed you need to be more productive, but there's no compromise on quality. What's more, thanks to mobile printing and Easy Printer Manager software, these printers are also designed to be easy to use.
Print fast, don't wait
However demanding your professional printing needs, a Samsung Xpress M2875FD Series gives you great results - fast. Save time by printing even complex documents at speeds of up to 28 pages per minute (PPM) thanks to a powerful 600MHz processor and 128MB of memory. With the Cortex-A5 Core, it's up to 25.6% faster than earlier models, making it one of the fastest printers in its class. That means it helps you to work faster, be more flexible and more produc-tive.
Give a good impression with great print quality
Now impressive professional-quality prints are possible for everyone. Your Samsung Xpress M2875FD Series delivers sharp, clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher perfor-mance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text.
High-resolution printing
Even complex images and small text are delivered in fine, detailed prints, thanks to high-resolution print quality up to 4800 x 600 dpi effective
Edge enhancement
Enjoy clearer text and more vivid images thanks to edge enhancement, which gives them a far more polished and well-defined edge.
Great copying and clear, colourful scanning
With your Samsung Xpress M2875FD Series, superior-quality copies and scans are now a reality. Great performance means fine text and images are sharper, delivering much more legible text and vibrant, smooth images.
Enhances thin lines and small text
Unlike some others, Samsung Xpress M2875FD Series ensure thin lines and small text are captured when scanning or copying. De-Integrated Cavity Effect (De-ICE) technology maximises the amount of text that is captured, delivering higher-quality prints and scans.
No more halftone patterns
With a Samsung Xpress M2875FD Series, you can remove halftone patterns on images and enjoy the clear and smooth images you need for truly pro-fessional print results.
Print with more paper types for all kinds of uses
Whatever you need to print, your Samsung Xpress M2875FD Series can handle it. The small but robust printer can use a range of media up to 220 grams per square meter (gsm), including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. You can easily select the paper type you need from the multipurpose (MP) tray, so it's convenient as well as flexible.
Better for your budget and the planet
Cut your toner and paper costs with the One-Touch Eco Button. It's optimised, so just a click of the button allows you to easily use N-up and duplex printing, which lets you print multiple document pages on a single sheet and skip wasteful blank pages. With toner save mode, you can also reduce toner use and bring your printing costs down even more.
Cut energy and supply consumption
With Easy Eco Driver, you can make savings of up to 20% on toner and paper as well as reducing your energy usage. It helps you cut down on page elements that use high amounts of toner, such as images and bold type fonts, or lighten text so that less toner is required. You can preview and edit your documents before print-ing, to make sure that the output meets your needs in terms of efficiency and also quality. Eco Simulator also shows you the estimated reduction percentage of CO2, electricity, and paper, so you can see the difference for yourself.
Cut costs with Separated Toner System
With Samsung's Separated Toner System, the toner cartridge and imaging unit are supplied separately. This means you only need to buy the toner cartridge when it's empty, so the overall cost of running the printer - and the cost per page - is reduced. Installation is also easy, so you can spend less time maintaining your printer as well as less money. You can balance your budget as well as meet all your printing needs.
Monitor and manage your printer easily
Samsung's Easy Printer Manager lets you look after your printer's settings, device status, supply ordering and faxing - all in one place. You can conveniently see error reports and monitor the status of your printer and its supplies, as well as manage settings remotely. It's all provided in one single interface that brings together all your Samsung Printer's settings and applications.
Duplex printing
Duplex printing, or printing on both sides of paper, helps ensure that a minimal amount of paper and toner are wasted. Eco Mode lets you make sure all documents use duplex printing, so you can use supplies more efficiently and reduce your impact on the environment.
Network connectivity
Connect your printer across many different PCs and other devices that are connected to a single router. With this arrangement, it's possible for you to reduce the amount of money you spend on printing devices and energy consumption, yet be as productive as ever.
Mobile printing
Print what you need, wherever you are. You can now print a wide range of files on the go using a mobile device. Thanks to the included Google Cloud Printâ„¢, you're also able to print and share all your emails, photos, PDF documents, and SNS messages.
Fax
Thanks to built-in fax capabilities, you don't need a separate fax machine anymore. You can also transmit faxes remotely from your mobile devices, so you can send that important document wherever you are, without needing to return to your home or office.
However demanding your professional printing needs, the Samsung Xpress M2875FD gives you great results - fast. Save time by printing complex documents at speeds of up to 29 pages per minute (PPM) thanks to a powerful 600 MHz processor and 128 MB of memory. With the Cortex-A5 processor, it's up to 25.6% faster than earlier models, making it one of the fastest printers in its class. That means it helps you to work faster, be more flexible and more productive. -
Now impressive professional-quality prints are possible for everyone. The Samsung Xpress M2875FD delivers sharp clear prints that are sure to make a big impact. Thanks to its 4800 x 600 dpi effective resolution and Rendering Engine for Clean Page (ReCP) technology, you can enjoy higher performance and quality without the need for a bulky larger printer. What's more, quality-boosting features give you more detail, smoother images and clearer text. -
High resolution printing
Even complex images and small text are delivered in fine, detailed prints, thanks to high-resolution print quality up to 1800 x 600 dpi effective. -
Edge enhancement
Enjoy clearer text and more vivid images thanks to edge enhancement, which gives them a far more polished and well-defined edge. -
Enhance fine lines and small text
Unlike some others, Samsung Xpress M2875FD series ensure thin lines and small text are captured when scanning or copying. De-Integrated Cavity Effect (De-ICE) technology maximizes the amount of text that is captured, delivering higher-quality prints and scans. -
With a Samsung Xpress M2875FD series MFP, you can remove halftone patterns on images and enjoy the clear and smooth images your need for truly professional print results. -
Regardless of what you need to print, the Samsung Xpress M2875FD can handle your needs with ease. The small but robust printer can use a range of media up to 59 lb. stock, including paper, labels, cards, envelopes and overhead projector (OHP) transparencies. Selecting customer paper types through the driver is easy, and loading them through the multi-purpose bypass is convenient as well. -
Cut your toner and paper costs with the one-touch eco button. It's optimized, so just a click of the button allows you to easily use N-up and duplex printing, which lets you print multiple document pages on a single sheet and skip wasteful blank pages. With toner save mode, you can also reduce toner use and bring your printing costs down even more. -
With the easy eco driver, you can see savings of up to 20% on toner and paper as well as reducing your energy usage. It helps you cut down on page elements that use high amounts of toner, such as images and bold type fonts, or lighten text so that less toner is required. You can preview and edit your documents before printing, to make sure that the output meets your needs in terms of efficiency and also quality. The eco results simulator also shows you the estimated reduction percentage of CO2, electricity, and paper, so you can see the difference for yourself. -
Cut costs with separated toner system
With Samsung's separated toner system, the toner cartridge and imaging unit are supplied separately. This means you only need to buy the toner cartridge when it's empty, so the overall cost of running the printer - and the cost per page - is reduced. Installation is also easy, so you can spend less time maintaining your printer as well as less money. You can balance your budget as well as meet all your printing needs. -
Samsung's easy printer manager lets you look after your printer's settings, device status, supply ordering and faxing - all in one place. You can conveniently see error reports and monitor the status of your printer and its supplies, as well as manage settings remotely. It's all provided in one single interface that brings together all your Samsung printer's settings and applications.
- Samsung Xpress M2875FD - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 12000 impressions
- Max Copying Speed
- Up to 28 ppm
- Max Printing Speed
- Up to 28 ppm
- Max Printing Resolution
- Up to 4800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- 142 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, card stock
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- 40.1 cm x 36.2 cm x 36.7 cm
- 11.3 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - monochrome
- 12000 impressions
- Display
- 2 lines
- Interface
- USB 2.0, LAN
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Up to 28 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2-up, 4-up, ID Card Copy, collation copy
Printing
- Up to 28 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, SPL
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 600 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 209 stations
- Fax forwarding, automatic redialing, last number redial, multi-send, delayed sending
Document & Media Handling
- Min Original Size
- 142 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 120 sheets
- ADF - 40 sheets size: 142 x 148 mm - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 120 sheets
- Speed Details
- Printing: up to 28 ppm (A4) - B/W , Printing: up to 29 ppm (Letter A) - B/W , Copying: up to 28 ppm (A4) - B/W , Copying: up to 29 ppm (Letter A) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Apple Mac OS X 10.5 - 10.8
- Software Included
- Drivers & Utilities
- 400 Watt
- Power Consumption Standby
- 50 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 15 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 40.1 cm
- 36.2 cm
- 36.7 cm
- 11.3 kg
- Sound Emission
- 26 dBA (idle) / 52 dBA (operating)
