Canon i-SENSYS LBP325x Mono Laser Printer
Quicklinx: FRZ6WS00 Mfr#: 3515C013
Get superior print speeds and flexible media handling with this compact black and white single-function laser printer.
Canon i-SENSYS LBP325x in More Detail
Ideal for handling heavy workloads, the Canon i-SENSYS LBP325x is a hard-working black and white laser printer that offers super-fast printing speeds and user-friendly controls in a compact, space-saving footprint. With a large paper capacity and flexible media handling options, it’s ready to maximise your output and push your business productivity.
Fast and flexible
The Canon i-SENSYS LBP325x has been specifically designed to meet the demands of busy offices and is capable of handling even the most demanding print runs both quickly and efficiently. It offers rapid print speeds of up to 43ppm in A4 and up to 65ppm in A5, together with automatic double-sided printing and a high-capacity 550 sheet paper tray, which can be boosted further still by using three optional paper cassettes that can hold 550 sheets each.
High-quality printing
You can rely on the Canon i-SENSYS LBP325x to produce high-quality prints day after day, week after week. It’s efficient, too, with improved high-yield cartridges that allow you to print even more pages between refills.
Seamless connectivity
High-speed USB connections and Ethernet compatibility make it easy to get connected in the office. You’ll be up and running in no time, freeing you to concentrate on what you do best and get on with the task at hand.
Easy-to-use
The clear five-line LCD display and intuitive interface allows easy operation of the printer and puts all its various functions at your fingertips.
Space-saving design
The Canon i-SENSYS LBP325x delivers high-performance printing and a large paper capacity in a small footprint, making it ideal for smaller office environments where space is at a premium.
Low running costs
This single-function laser printer has been designed to deliver maximum efficiency and low running costs. Standard cartridges can print up to 5,100 pages, while optional high-yield cartridges take this up to 21,000 pages.
  • High-speed printing
    Accelerate your business's productivity with superior print speeds of 43 ppm and 65 ppm for A4 and A5 respectively.
  • Small footprint
    Maximize space in a smaller office with an efficient and compact single-function printer.
  • Easy operation
    Take control with a user-friendly and intuitive 5-Line LCD display.
Canon i-SENSYS LBP325x - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
12.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 43 ppm - B/W - A4 (210 x 297 mm) , Up to 36 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PostScript 3, PCL 6, PDF, XPS, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, postcards, coloured paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet paper cassette
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.9.5 or later, Microsoft Windows Server 2019, Apple macOS 10.14
40.9 cm x 37.6 cm x 27.5 cm
2-year Limited Warranty
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5.7 sec
Language Simulation
Fonts Included
105 x PCL , 136 x PostScript
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 199 g/m²
650 sheets
Media Feeders
Paper cassette: 1 - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
150000 pages
2000 - 7500 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 5100 pages - Canon 056L
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1380 Watt
Power Consumption Stand by
10.1 Watt
Power Consumption Sleep
1.2 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
54 dBA
40.9 cm
37.6 cm
27.5 cm
12.3 kg
