Samsung LED Wall Mount
Quicklinx: 5JHYWS00 Mfr#: WMN1000BXXC
The Samsung ultra slim wall mount (WMN1000B) is a unique and simple mounting solution dedicated for use with select Samsung flat panel TVs.
Samsung WMN1000B - mounting kit - for flat panel
Mounting kit - wall-mountable
Mounting Components
Wall mount
Recommended Use
Flat panel
Recommended Display Size
40"-55"
Max Load Weight
49.9 kg
Samsung UA40C7000, UA46C7000, UA46C8000, UA55C7000, UA55C8000, UA55D7000, UE40C7000, UE40C9000, UE40D6000, UE40D7000, UE40D8000, UE46C8000, UE46D6000, UE46D7000, UE46D8000, UE55C8000, UE55D6000, UE55D7000, UE55D8000, UN40D6000, UN46D6000, UN46D7000, UN46D8000, UN55D6000, UN55D7000, UN55D8000
AV Furniture
Mounting kit
Mounting Components
Wall mount
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
40"-55"
Max Load Weight
49.9 kg
Samsung UA40B6000, UA40C7000, UA46B6000, UA46B8000, UA46C7000, UA46C8000, UA55B6000, UA55B8000, UA55C7000, UA55C8000, UA55D7000, UE40B6000, UE40B6000VW, UE40B7000, UE40B8000, UE40C6000, UE40C7000, UE40C8000, UE40C9000, UE40D6000, UE40D7000, UE40D7000LS, UE40D8000, UE40D8000YU, UE46B6000, UE46B7000, UE46B8000, UE46B8000XW, UE46C6000, UE46C7000, UE46C8000, UE46D6000, UE46D7000, UE46D8000, UE55B7000, UE55B7000WW, UE55C6000, UE55C7000, UE55C8000, UE55D6000, UE55D7000, UE55D7000LS, UE55D8000, UN40B6000, UN40B6000V, UN40B7000, UN40C7000, UN40D6000, UN46B6000, UN46B7000, UN46B8000, UN46B8000XF, UN46C7000, UN46C8000, UN46D6000, UN46D7000, UN46D8000, UN55B6000, UN55B7000, UN55B8000, UN55C7000, UN55C8000, UN55D6000, UN55D7000, UN55D8000
