Peerless-AV PT632 Universal Tilt Wall Mount for 22" - 40" LCD Screens
Quicklinx: 7HCKWS00 Mfr#: PT632
Type: Mounting kit
£29.39 ex VAT
£35.26 inc VAT
Ideally suited for medium (22-40") LCD screens, the Paramount PT632 tilting wall mount allows you to mount your LCD screen quickly and easily and tilt it forward/back for an improved viewing angle.
  • Easy installation
    The Peerless PARAMOUNT Tilting Wall Mount features a Hook-and-Hang system, making the installation process straightforward and hassle-free. This system allows for easy leveling and positioning of your LCD TV, ensuring an improved viewing angle.
  • Durable design
    Constructed from high-quality steel and designed to be scratch-resistant, this mounting kit is built to last. It supports LCD TVs from 22" to 40", handling a maximum load weight of 36 kg, making it a reliable choice for securing your television.
  • Versatile viewing angles
    With the ability to tilt from -5° to 15°, the Peerless PARAMOUNT Tilting Wall Mount offers flexible viewing options. This feature ensures that you can adjust the viewing angle to reduce glare and enhance your viewing experience.
Peerless PARAMOUNT Tilting Wall Mount PT632 mounting kit - for LCD TV - gloss black
Mounting kit
Mounting Components
Wall plate, mounting adapter, mounting plate
22.2 cm 22.2 cm
Adjustable Depth
5.1-9.6 cm
Tilt
-5° to 15°
0.8 kg
Recommended Use
LCD TV
Recommended Display Size
22"-40"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
36 kg
Material
Steel
Gloss black
22.2 cm
22.2 cm
Adjustable Depth
5.1-9.6 cm
0.8 kg
Material
Steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD TV
22"-40"
Tilt
-5° to 15°
Max Load Weight
36 kg
Scratch-resistant, Hook-and-Hang
Type: Mounting kit
Brand: Peerless-AV
