Peerless-AV Universal Flat Wall Mount for 39" to 80" Displays
Quicklinx: 7MVQWS00 Mfr#: PF660
Type: Mounting kit
34 In Stock
£57.85 ex VAT
£69.42 inc VAT
Ideally suited for extra large LCD and plasma screens, the Paramount PF660 flat-to-wall mount allows you to mount your LCD/plasma screen quickly and easily. The low profile design holds the screen only 43mm away from the wall.
  • Durable design
    Crafted from cold-rolled steel, this mounting kit offers a scratch-resistant finish, ensuring longevity and maintaining its sleek look over time.
  • Versatile compatibility
    Designed to support flat panels ranging from 39" to 90", the Peerless PARAMOUNT Universal Flat Wall Mount accommodates a wide variety of screen sizes, making it an ideal choice for various display needs.
  • Robust support
    With the ability to hold up to 90.8 kg, this mounting kit provides a secure and stable platform for your flat panel, ensuring safety and peace of mind.
Peerless PARAMOUNT Universal Flat Wall Mount PF660 mounting kit - for flat panel - gloss black
Mounting kit
Mounting Components
Wall plate, bracket adapter
78.1 cm x 4.3 cm x 45.7 cm
3.5 kg
Recommended Use
Flat panel
Recommended Display Size
39"-90"
Max Mounting Pattern Size
825 x 450 mm
Max Load Weight
90.8 kg
Material
Cold-rolled steel
Gloss black
5-year warranty
78.1 cm
4.3 cm
45.7 cm
3.5 kg
Material
Cold-rolled steel
Gloss black
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
825 x 450 mm
39"-90"
Max Load Weight
90.8 kg
Scratch-resistant
Limited warranty - 5 years
Type: Mounting kit
Brand: Peerless-AV
