Samsung HW-F550 46" Soundbar with Wireless Sub
Quicklinx: 8ZRVWS00 Mfr#: HW-F550
Discover powerful audio that fits your home perfectly. The slim and stylish Samsung HW-F550 Soundbar can connect to your television wirelessly, so you can place it wherever you want without having to worry about trailing cables. It also offers Samsung's unique 3D Sound Plus technology, delivering incredibly realistic 3D sound to perfectly accompany 3D viewing. You can even control both your TV and Soundbar with only one remote control.
Connect and share wirelessly for more convenience.
Connect your TV and Soundbar easily through Bluetooth to gain better sound with SoundShare. The absence of trailing wires between the Soundbar and TV allows you to showcase the slim and sleek design of both systems, while maintaining a clean look in your living environment. Easily control the Soundbar and TV from a single TV remote. You can simultaneously turn on and manage the volume of your TV and Soundbar with Bluetooth or HDMI connectivity.
  • SoundShare is only available for select Samsung 3D TVs.
    [2013] LED Series 6400 or higher and PDP Series 5500 or higher.
    [2012] LED Series 6100 or higher and PDP Series 550 or higher.
Slim design that appeals to your senses
Get a speaker that matches your style and complements your home. The Samsung Soundbar suits any home entertainment layout. Its stunningly slim black design perfectly complements the premium design of a Samsung TV. The Soundbar is simple to setup and maintain since no wires are required. Its wireless convenience creates a neat, clean and elegant look for your entertainment environment.
3D Sound Plus
3D Sound Plus, Samsung's unique sound processing technology, combines its latest advancements in sound, 3D depth Sound and Horizontal Surround, to deliver a more realistic 3D experience for a truly heart-pounding, immersive adventure.
Experience the richness of bass sounds
Combine the simplicity of the Soundbar with the thunderous bass sound quality to give you a truly enriching sound environment. The supersonic sub-woofer that accompanies Samsung's Soundbar adds dynamic and rich bass levels to your listening experience. Its wire-free design makes it easy to set up and to adjust around the room to give you the best bass effect. Increase the potential of your sound experience with the wireless Soundbar.
HDMI (ARC)
HDMI ARC (Audio Return Channel) allows you to easily connect compatible devices to process the TV's audio signal without a separate optical cable to your receiver. Two HDMI inputs keep your AV devices connected with fewer cables for a totally new audio experience.
Bluetooth
Bluetooth is the new way of connecting device to device wirelessly. Samsung audio system is equipped with Bluetooth, it can connect with compatible portable devices wirelessly. Listen to music using your portable music player or even cellular phone without connecting wires.
  • Wireless active subwoofer
    Enhance your TV experience and feel the power of tight, thundering bass when you're watching your favorite movies and shows. The Wireless active subwoofer adds powerful bass from anywhere in the room and gives you a truly rich sound experience.
  • Bluetooth
    Enjoy wireless connectivity with Bluetooth and stream your favorite music from your connected mobile devices.
  • Smart volume
    Easily control the volume of your Samsung TV and AudioBar with your Samsung TV remote through a Bluetooth or HDMI connection.
  • HD sound
    When you're watching TV, nothing enhances the movie, show or concert like deep, full, powerful sound. Hear it once and you can't go back. High definition sound immerses you in an amazing acoustic experience. Hear every instrument and sound effect with greater audio quality.
  • Design
    The stunningly slim metal design adds unique style to your home. The AudioBar is simple to set up and maintain. With no wires necessary, it's not only convenient but also offers a clean and elegant look that complements any home entertainment layout.
  • 3D Sound Plus
    Complement the images you see on screen with the full sound of 3D Sound Plus. By analyzing the depth of the 3D image, 3D Sound Plus synchronizes the sound to match the motion and depth of the image. Now you can enjoy a fully immersive 3D experience.
  • HDMI
    Get superior picture and sound from your HD source with High-Definition Multimedia Interface (HDMI) - a digital connection that can transmit HD video and audio over a single cable.
  • Anynet +
    Enjoy one-touch control for all your Samsung HDMI-connected compatible devices with Anynet+.
Samsung HW-F550 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
310 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar , 1 x subwoofer
Built-in Decoders
Dolby Digital, DTS decoder
Sound Effects
3D surround sound
USB-host
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
310 Watt
Amplifier
Integrated
Sound Effects
3D surround sound
Audio Return Channel (ARC) Capability
Bluetooth
Built-in Decoders
Audio Formats
Additional Features
Speakers Included
1 x sound bar - wireless , 1 x subwoofer - wireless
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB 2.0 (4 PIN USB Type A) , Audio line-in , Digital audio input (optical) (TOS Link)
Audio cable, power adapter
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 94.3 cm x 6.45 cm x 5.53 cm / 1.86 kg , Subwoofer: 29.1 cm x 29.1 cm x 36.9 cm / 7.25 kg
