Samsung DM65E-BR 65" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Quicklinx: BKPHWS00 Mfr#: LH65DMERTBC/EN
  • 1080p
header
Introducing Samsung's NEW 65" eBoard solution.
Unleash the potential of your presentations.
A Smoother, More Interactive Writing Experience Using Touch
writing
Featuring a pre-assembled Touch Overlay and a variety of collabouration-enhancing capabilities, the Samsung e-Board display alleviates misconceptions that digital display writing is complex and unnatural. Instead, the DME-BR’s touchscreen offers a smooth and comfortable writing experience. The DME-BR display’s hand touch function enables up to 10 different participants to touch the display’s screen using two fingers to make content selections, comments or edits, with those individual actions easily recognisable to the entire group. This versatile usability promotes efficiency and productivity by compiling individual feedback within a single source and offering greater visibility to all participants of discussed content.
For added convenience, the Samsung e-Board display also comes with a hand eraser tool useful for erasing larger areas of the screen. Instead of users having to search for and work through a specific removal function key, the simple and intuitive hand eraser makes content revision fast and user-friendly.
A More Engaging, Interactive Content Management Experience
interactive
The Samsung SMART Signage e-Board display’s embedded Magic WB S2* interactive content management software solution transforms a traditional presentation into a dynamic business or educational experience. As an all-in-one touch solution, Samsung’s free Magic WB S2 programme delivers added flexibility for extensive collabouration before, during and after meetings or classes without requiring the use of separate dedicated PCs or additional devices. A touch-activated floating menu enables users to independently control, display and shuffle between multiple screens and various text, image, audio and video content files. Once sessions conclude, Magic WB S2’s compatibility with standard office software programs lets users update, save, capture, print and share files for later viewing. With the support of the Magic WB S2 solution, the Samsung e-Board display enhances the overall knowledge-sharing process through deeper engagement and all-inclusive file management.
*Note: Samsung’s Magic WB S2 software, an advanced version of Magic WB, is available for e-Board display users, but requires a separate PC for operation.
Versatile Usability with Extensive Connectivity and Easy-to-Use Touch Capability
versatile
Today’s business and educational environments require advanced compatibility for users to easily read and share content. Through its enhanced and versatile connectivity, Samsung’s e-Board display allows users to access, share and revise content via their own laptops, tablets and smartphones. This superior connectivity stems from the display being equipped to support a range of signal input sources, including HDMI, D-Sub, DisplayPort (DP), DVI and USB ports, which are compatible with nearly all external devices.
Furthermore, the Samsung e-Board display’s auto switching for the touch function eliminates the headache of needing two different cables to use touch with a notebook PC. Instead, the display features an easily assessable touch out cable (USB upstream) on the side of the front pen tray. Users just need to plug the single touch cable into the USB, connect the cable to the notebook PC and setup source. Together, these integrated solutions simplify multi-device setup and connectivity, as well as ensure convenient utilisation of the display’s advanced touch capability.
An Intuitive Design that Promotes Efficiency and Usability
intuitive
The Samsung SMART Signage e-Board display’s pre-assembled design allows users to comfortably install, control and work with the all-in-one e-Board solution. As part of its professional-grade design, the Samsung e-Board display incorporates a front pen tray for convenient storage and easy access to display components. With a design format resembling that of an analog white board, the Samsung e-Board helps ensure user familiarly and seamless technology adoption, while also bringing design sophistication and advanced functionality to business and educational environments. Additionally, the display’s design positions simplified hot keys on the front and side of the pen tray. The shortcut hot keys allow users to easily locate and select frequently-used functions, including touch on/off, quick menu, power on/off, touch out USB and HDMI, with the simple push of a button.
With the Samsung SMART Signage e-Board, business professionals and educators can economically utilise space while delivering the functionality essential for effective collabouration and productivity.
  • An integrated solution for your business or educational space that allows you to unleash the potential of your presentations
    Communication needs to evolve alongside this growth and act as a beacon of light to hold attention. Particularly when it comes to closing deals in business meetings or deeply connecting with the minds of the future in educational settings. Few environments stand to benefit more from interactive whiteboard solutions than corporate boardrooms and classrooms, where messages need to sink deep into their intended audience to make lasting impacts. Samsung has brought their e-Board Solution to these spaces and continues to tailor the user experience to achieve the desired outcomes that the user is seeking.
  • Building a productive workplace that ensures optimum levels of communication and collaboration
    Samsung e-Board acts as a conduit to bring efficiency to the workplace, through fostering an atmosphere for enhanced communication and immersive collaboration. With e-Board in the boardroom, brainstorming and idea-sharing have never been better supported through its interactive display that facilitates rapid idea generation, retention and application. Deep dissemination of product or service knowledge between product development teams and sales teams can now be achieved through collaborative exchanges involving IWB and a captive audience that can now find themselves fully interactive, while never having to leave the comfort zone beyond their laptops and mobile devices.
  • The lines of communication between teachers and students with an interactive presentation environment
    Gone are the days of educators needing to factor in the logistics of a typical projector system and the pitfalls and distractions that they come with. Samsung e-Board converts these past shortcomings into strengths through effective utilization of FHD displays and interactive whiteboards. The lines of communication between teachers and students can now be forged, through data and filesharing capabilities between the e-Board and devices of students, thus further creating an interactive presentation environment that holds attention spans and creates opportunity to diversify learning approaches. Samsung e-Board is well suited to help you convert your classroom into an intensive and engaging learning environment.
  • Allow MagicIWB S2 to bring your boardroom to life with vivid and engaging presentations
    In this era of information overload, it has become critical to use time effectively to get your message across, while ensuring that your audience remains captive. A challenging task, however, Samsung MagicIWB S2 was built to give you a layer of support when seeking to deliver vivid, presentation-oriented meetings. This convenient solution comes embedded in the DME-BR series, which brings a dimension of portability and ease-of-use that catapults it to the forefront of e-board technology. MagicIWB S2 is perfectly tailored to be used in the dynamic spaces and settings of modern offices through use of a range of featurerich capabilities that have been crafted to make your presentations more productive, regardless if you consider yourself to be a quick or slow adopter of technology.
  • Discover levels of engagement with MagicIWB I2 by converting listeners into participants
    MagicIWB I2 is an optional advanced e-Board solution which is provided with selective Samsung PIM (Plug-in-Module) and it can run on the DME-BR series by simply adding the PIM. MagicIWB I2 acts as a foundation to facilitate highly collaborative and interactive business and educational situations. Through proper utilization of MagicIWB I2's interactive whiteboard, the traditional roles of speaker and listener are now able to evolve into roles of facilitator and participant, where the audience is able to find themselves immersed in a environment that brings them further into the learning and information sharing experience through expanded capabilities.
  • Ready-to-use, all-in-one e-board display package with Hand Touch and MagicIWB software
    The touch interfaces that you have come to know and depend on for daily use, such as with smartphones, have transcended personal use and are now embedded in the e-Boards. Employing those same gestures, habits and ease-of-use, the learning curve for adjusting to the Hand Touch e-Board will be understandably short.
  • Embrace the frontier of e-board technology from Samsung MagicIWB
    Leveraging Samsung's aspiration for creating dynamic and highly usable platforms, Samsung MagicIWB takes your e-Board experience to the next level with heralded innovations that allow for your educational and business environments to become more immersive and your audiences to become more engaged. Let Samsung MagicIWB lead your way forward to realize new horizons of communication.
Samsung DM65E-BR DME Series - 65" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
120Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Remote control, pen, pen tray, batteries
Voltage
Energy Class
Class B
264 Watt
Power Consumption (On mode)
200 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
292 kWh
153.53 cm x 7.66 cm x 91.04 cm
46.1 kg
Energy Class
Class B
264 Watt
200 W
292 kWh
Diagonal Class
65"
Commercial Use
Combined With
Touchscreen
Series
DME Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
153.53 cm
7.66 cm
91.04 cm
46.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
50000:1
Brightness
380 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.248 x 0.744mm
Response Time
6 ms
Commercial Features
Multiple Display Control (MDC), MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , 2 x HDMI input - rear , Audio line-in , Composite video / component video input , Audio line-out , DisplayPort input , HDMI input - front
Pen, pen tray, batteries
Serial adapter
CSA, UL, TUV, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, NOM, SASO, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 13439, CNS 14972, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
0.5 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
166.5 cm
Depth (Shipping)
25 cm
Height (Shipping)
104 cm
Weight (Shipping)
54.1 kg
10 - 80%
