The MultiXpress C9352NA enhance office productivity with faster printing and scanning capabilities, powered by a fully integrated Samsung 1 GHz dual-core processor. Large print and copy jobs are easier to manage, and scanning throughput is increased. The dual-core processor performs printing tasks faster than a conventional processor, enabling employees to focus on core work activities.
Samsung's unique ReCP (Rendering Engine for Clean Page) technology and up to 600 x 600 x 4 bit dpi improve the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
Samsung polymerized toner produces smaller and more uniform particles than conventional toners. Printouts have crisper lines and intense colors, and pages curl less often. Additionally, the high wax content improves the image gloss and durability, which helps prevent the document from fading.
The combined boards and chips that make up the All-in-One Board help reduce the number of complex parts, decreasing the failure rate. The All-in-One Board assists in controlling overall energy consumption by lowering power requirements. When compared to a conventional board during an internal test, the all-in-one board helped reduce Typical Electricity Consumption (TEC) by up to 44.2 percent. Samsung Instant Fusing System (IFS) technology also helps increase printing and copying speed. In addition, IFS reduces energy use, which further aids in controlling operating costs.
Improve performance with twice the power
The MultiXpress C9352NA enhance office productivity with faster printing and scanning capabilities, powered by a fully integrated Samsung 1 GHz dual-core processor. Large print and copy jobs are easier to manage, and scanning throughput is increased. The dual-core processor performs printing tasks faster than a conventional processor, enabling employees to focus on core work activities. -
Enjoy quality printouts
Samsung's unique ReCP (Rendering Engine for Clean Page) technology and up to 600 x 600 x 4 bit dpi improve the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps. -
Prevent document fading with polymerized toner
Samsung polymerized toner produces smaller and more uniform particles than conventional toners. Printouts have crisper lines and intense colors, and pages curl less often. Additionally, the high wax content improves the image gloss and durability, which helps prevent the document from fading. -
Low power consumption
The combined boards and chips that make up the All-in-One Board help reduce the number of complex parts, decreasing the failure rate. The All-in-One Board assists in controlling overall energy consumption by lowering power requirements. When compared to a conventional board during an internal test, the all-in-one board helped reduce Typical Electricity Consumption (TEC) by up to 44.2 percent. Samsung Instant Fusing System (IFS) technology also helps increase printing and copying speed. In addition, IFS reduces energy use, which further aids in controlling operating costs. -
Reduced downtime for maintenance
Decreased maintenance and installation times help businesses meet deadlines within budget. Toner replacement for the MultiXpres C9352NA printers is designed for ease of use. In addition, users can correct paper jams without the need for a maintenance call. Fewer steps are required to replace high-frequency service items (HFSIs), such as fusers, rollers and image transfer units (ITUs). Fewer maintenance steps means the device is more readily available when users need it. -
Simplified savings with the touch of a button
Businesses can lower operating expenses with greater ease using eco mode, an energy-saving feature that helps companies reduce paper and power costs. Based on an internal Samsung test, Samsung MFPs with eco mode outperformed an MFP without eco mode: easy eco driver provides users a preview of a document before printing, which helps reduce wasted printouts. While previewing the document, users can modify its format by removing text and images. -
LCD control panel that is largest in its printer class
The color LCD control panel on the MultiXpress C9352NA MFPs is 8.9 inches and is considered one of the largest MFPs in its class. The control panel tilts for convenient viewing of the current job status, following prompts during an operation and setting up menus. Also, LED indicators, such as low paper alerts or a ready-for-use indicator, help users more quickly determine the device status. -
XOA (Open Architecture Platform)
Enjoy the freedom of connecting your multifunctional product to your line-of-business applications through the unique Open Architecture Platform (XOA). Based on open standards, XOA allows print solution vendors to create embedded applications that enhance the use of the device's capabilities to improve business processes.
- Samsung MultiXpress 9352NA - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 150000 impressions
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Scanning
- 600 x 600 dpi
- Display
- 8.9"
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 98 x 148 mm (min) - 320 x 457 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, heavy-weight paper, thin paper, thick paper, card stock
- Standard Media Capacity
- 1140 sheets
- Max Media Capacity
- 3140 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network, save to HDD
- 67.75 cm x 76.3 cm x 85.36 cm
- 109.5 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - colour
- Display Diagonal Size
- 8.9"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1.5 GB 1.5 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- ID Card Copy, Poster Copy, Clone Copy
Printing
- Printer Drivers / Emulations
- PostScript 3, PDF 1.7, PCL 6C, PCL 5ce
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- 1140 sheets
- 3140 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets , Bypass tray - 100 sheets , Output tray - 500 sheets , 2 x paper cassette - 520 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (Letter A) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 35 ppm (Letter A) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (Letter A) - B/W , Copying: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (Letter A) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- SSL, TLS, IPsec, IP filtering, MAC address filtering
- Operating System Support
- MS Windows XP, MS Windows Server 2003, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Desktop 10, openSUSE 10.2, openSUSE 10.3, openSUSE 11.0, openSUSE 11.1, Ubuntu Linux 7.10, Ubuntu Linux 8.10, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Debian Linux 5.0, Debian Linux 4.0, Ubuntu Linux 6.06, Ubuntu Linux 6.10, Ubuntu Linux 7.04, Ubuntu Linux 8.04, Red Hat Fedora Core 2-10, SuSE Linux 9.1, OpenSUSE 9.2, OpenSUSE 9.3, OpenSUSE 10.0, Mandrake Linux 10.0, Mandrake Linux 10.1, Mandriva 2005, Mandriva 2006, Mandriva 2007, Mandriva 2008, SuSE Linux Enterprise Desktop 9, Debian Linux 3.1, Windows 8, Apple Mac OS X 10.4 - 10.8, OpenSUSE 10.1, Mandriva 2009
- Software Included
- Drivers & Utilities
- 1.1 kW
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 7.5 sec
- First Copy Out Time Colour
- 8.5 sec
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (yellow/cyan/magenta)
- WHQL, CCC, IPv6 Ready, ISO 15408
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 67.75 cm
- 76.3 cm
- 85.36 cm
- 109.5 kg
- Shipping Width
- 98 cm
- Shipping Depth
- 77 cm
- Shipping Height
- 110 cm
- Sound Emission
- 27 dBA (idle) / 54 dBA (operating)
