When your business regularly needs to deliver big print or copy jobs and deliver them quickly, then you'll find that the CLX-8640ND is up the task with power to spare. With fast printing and scanning capabilities provided by a fully integrated Samsung 1 GHz Dual Core processor, office productivity increases dramatically. Large print/copy jobs are finished faster, and scan throughput is swifter. In fact, every document task you perform with the CLX-8640ND is 1.5 times quicker, allowing you to spend more time working and less time waiting around.
Scanning takes less time now too. You can enjoy the fastest duplex scan speed of any multifunction device - an impressive 70 ipm. Forget waiting forever for printouts. With an incredible 38 pages printing per minute, it's the quickest printer and copier around.
Twice the power delivers high performance
When your business regularly needs to deliver big print or copy jobs and deliver them quickly, then you'll find that the CLX-8640ND is up the task with power to spare. With fast printing and scanning capabilities provided by a fully integrated Samsung 1 GHz Dual Core processor, office productivity increases dramatically. Large print/copy jobs are finished faster, and scan throughput is swifter. In fact, every document task you perform with the CLX-8640ND is 1.5 times quicker, allowing you to spend more time working and less time waiting around. -
Reduce job time with faster scanning and printing
Scanning takes less time now too. You can enjoy the fastest duplex scan speed of any multifunction device - an impressive 70 ipm. Forget waiting forever for printouts. With an incredible 38 pages printing per minute, it's the quickest printer and copier around. -
Save time with reliability that won't let you down
Busy businesses can't afford to waste time with unreliable products. That's why the anti-jam technology stops stress-causing device blocks by using a roller that provides a backward friction during the paper pickup process. And with a monthly duty cycle of 200,000, productivity is kept steady and reliable.
- Samsung CLX-8640ND - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 200000 impressions
- Max Copying Speed
- Up to 38 ppm (mono) / up to 38 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- 1200 x 600 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- 145 x 145 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 92 x 148 mm (min) - 216 x 1200 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, thin paper, thick paper
- Standard Media Capacity
- 620 sheets
- Max Media Capacity
- 2180 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network
- 55 cm x 52.3 cm x 77.6 cm
- 70.4 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1 GB 1 GB
- Max Supported Memory
- 1 GB 1 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Fit to page, ID Card Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.7
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Document & Media Handling
- Min Original Size
- 145 x 145 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 92 x 148 mm
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 92 x 148 mm, 216 x 1200 mm
- Supported Envelope Sizes
- International C5 (162 x 229 mm)
- 620 sheets
- 2180 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 145 x 145 mm - Legal (216 x 356 mm) , Paper cassette - 520 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 92 x 148 mm - 216 x 1200 mm weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 38 ppm (A4) - B/W , Printing: up to 40 ppm (Letter A) - B/W , Printing: up to 38 ppm (A4) - colour , Printing: up to 40 ppm (Letter A) - colour , Copying: up to 38 ppm (A4) - B/W , Copying: up to 40 ppm (Letter A) - B/W , Copying: up to 38 ppm (A4) - colour , Copying: up to 40 ppm (Letter A) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- SSL, IPsec, IP filtering
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, HP-UX 11i v3, Sun Solaris 9, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), HP-UX 11.0, HP-UX 11i v2, MS Windows Server 2008, Debian Linux 5.0, Apple Mac OS X 10.4 - 10.7, Fedora 5 - 13, Ubuntu Linux 6.06 - 10.04, SuSe Linux 10.1, Debian Linux 4.0, HP-UX 11i v1, IBM AIX 5.1 - 5.4, MS Windows Server 2008 R2 x64 Edition, openSUSE 10.2 - 11.2, Mandriva 2007 - 2010
- Software Included
- Drivers & Utilities
- 1600 Watt
- Power Consumption Sleep
- 1.5 Watt
- First Copy Out Time B/W
- 9 sec
- First Copy Out Time Colour
- 9 sec
- WHQL, CCC, ISO 15408
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 55 cm
- 52.3 cm
- 77.6 cm
- 70.4 kg
- Shipping Width
- 76 cm
- Shipping Depth
- 74 cm
- Shipping Height
- 110 cm
- Sound Emission
- 30 dBA (idle) / 59 dBA (operating)
