Samsung CLX 6260ND Colour Laser Multifunction Printer
Quicklinx: 877PWS00 Mfr#: CLX-6260ND/SEE
With 4-in-1 versatility, the Samsung CLX-6260ND printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy and scan functionality, the CLX-6260ND offers flexibility and lets you work with less barriers.
A host of innovative features like ID Copy, N-up copy and Scan-to-email ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
  • Enjoy quality printouts
    Samsung's unique ReCP (Rendering Engine for Clean Page) Technology and Up to 9600 x 600 dpi effective output improve the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Polymerized toner
    The developed polymerized toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid colours, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • More power, higher productivity
    Some days it seems like the printing never ends. With the CLX-6260ND's 533 MHz Dual CPU, and 512MB standard memory (expandable up to 1GB) you can be sure that this printer will handle the entire load of your workgroup's need.
  • Speedy and flexible paper handling
    If you want to print or copy onto heavier weights of paper, you can. Weights of up to 220g/m2 are handled with ease through the 50 page multipurpose tray as well as the 250 page standard cassette. That way you can also use up to three different media types without the need to waste time changing paper. You can enhance your productivity further still with the 50 page document feeder that can process single as well as double sided documents automatically.
  • 3-in-1 multifunction
    With 3-in-1 versatility, the Samsung CLX-6260ND printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy and scan functionality, the CLX-6260ND offers flexibility and lets you work with less barriers. A host of innovative features like ID Copy, N-up copy, Scan-to-email functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
Samsung CLX-6260ND - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
60000 impressions
Max Copying Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
1200 x 1200 dpi (colour)
Max Printing Speed
Max Printing Resolution
9600 x 600 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, film, thin paper, thick paper
Standard Media Capacity
300 sheets
Max Media Capacity
820 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to application, scan to network
42 cm x 45.25 cm x 47.68 cm
24.8 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
60000 impressions
Display
4 lines
Max Supported Memory
512 MB 512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PostScript 3, PCL 5c, SPLC, PDF 1.7, PCL 6C
Automatic Duplexing
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
300 sheets
Max Media Capacity
820 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Copying: up to 24 ppm (A4) - colour , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 25 ppm (Letter A) - colour , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4 - 10.7
450 Watt
Power Consumption Standby
16 Watt
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
17 sec
First Copy Out Time Colour
17 sec
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
ISO 19798
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
42 cm
45.25 cm
47.68 cm
24.8 kg
Shipping Width
58 cm
Shipping Depth
56 cm
Shipping Height
62 cm
Sound Emission
54 dBA (operating)
