True colour and truly compact design
- Print vividly thanks to new polymerised toner
- Save space thanks to compact ergonomic design
- Easily print screen or eco-optimise your output
- Create and use Easy Colour Manager profiles
The Samsung CLP-360 printer uses minimal space but still prints with maximum color. It uses ReCP technology and polymerized toner to give you vivid true color printing. What's more, its ergonomic design means that it takes up less space, so it fits into your surroundings perfectly. The CLP-360 is also easy to use and efficient, with a one touch eco button to help you save print supplies and energy. You can even print the screen contents instantly with just one click using the one touch print screen button.
Enjoy quality printouts
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
Polymerised toner
Our newly developed polymerised toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colours - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
Ergonomic design
Don't worry about this printer crowding your space.
Its beautiful and compact design makes it a pleasure to share a desk with.
Small size Footprint
With a footprint of just 38.2 x 30.9 cm the CLP-360 is one of the world's smallest colour laser printers.
Ergonomic design
Its ergonomic design with ebony brown and ice grey colour creates a modern and elegant work environments.
Easy to use
Designed for simple and intuitive operation the CLP-360 saves you precious time and effort.
One Touch Eco Button
Just One push of the ECO button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change colour to greyscale or skip blank pages.
One Touch Print Screen Button
Print exactly what you see on the screen with just one click, saving time.
Easy Colour Manager
Create and use your own colour profiles with Samsung's Easy Colour Manager. Match the exact colours of a company logo or simply give your print outs the individual look you want.
Easy Solution support
The printer also brings you software support designed to put you in control of delivering ultimate quality printouts easier than ever before.
Easy Eco Driver
Easy Eco Driver helps you compile digital documents in multiple formats and makes it easy to share them with others - even through social networks.
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps. -
Ergonomic design
Don't worry about this printer crowding your space. Its beautiful and compact design makes it a pleasure to share a desk with. Small size FootprintWith a footprint of just 38.2 x 30.9 cm the CLP-360 is one of the world's smallest colour laser printers. Ergonomic designIts ergonomic design with ebony brown and ice grey colour creates a modern and elegant work environments. -
Polymerised toner
Our newly developed polymerised toner has smaller and more uniform particles than conventional toner. Meaning, your printouts will have crisper lines and more vivid colours - helping avoid any paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading. -
Easy Colour Manager
Create and use your own colour profiles with Samsung's Easy Colour Manager. Match the exact colours of a company logo or simply give your print outs the individual look you want. -
Easy to use
Designed for simple and intuitive operation the CLP-360 saves you precious time and effort.* One Touch Eco ButtonJust One push of the ECO button and you can save on toner, paper, and energy. Print multiple pages on one sheet, change colour to greyscale or skip blank pages.* One Touch Print Screen ButtonPrint exactly what you see on the screen with just one click, saving time.
- Samsung CLP-360 - printer - colour - laser
- Printer Type
- Personal printer - laser - colour
- 9.85 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 152.4 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 4 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 4 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (Colour)
- 2400 x 600 dpi
- Interface
- USB
- Processor
- 300 MHz
- RAM Installed (Max)
- 32 MB
- Language Simulation
- SPL (Samsung Printer Language)
- Media Type
- Labels, plain paper, cards, bond paper, recycled paper, cotton paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet paper cassette
- Monthly Duty Cycle (max)
- 20000 images
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4 - 10.7
- 38.2 cm x 30.9 cm x 21.1 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 2400 x 600 dpi
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 26 sec
- Media Handling
- Processor
- 300 MHz
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 152.4 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets
- Output Trays Capacity
- 50 sheets
Duty Cycle
- 20000 images
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- Power Device
- Power supply - internal
- 290 Watt
- Power Consumption Stand by / Sleep
- 60 Watt
- OS Required
- Sound Emission (Operating)
- 48 dBA
- 38.2 cm
- 30.9 cm
- 21.1 cm
- 9.85 kg
