The ZoneFlex 7025 integrates high speed 2.4 GHz 802.11n Wi-Fi technology with wired Ethernet ports into an elegant, inconspicuous and low-profile wall jack that fits into an electrical junction box. It's ideal for offering multiple connections into hotel guest rooms and university dormitories without multiple cables. It delivers high performance Wi-Fi coverage and four wired Ethernet connections and an additional pass-through port for digital phones that requires native access to an in-house PBX system.
- Ruckus ZoneFlex 7025 Wi-Fi Wall Switch - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- Worldwide
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Performance
- Throughput: 85 Mbps
- Capacity
- Concurrent users: 100 , VoIP calls: 10
- Power Over Ethernet (PoE) Supported
- PoE
- 8.5 cm x 8.5 cm x 5.6 cm
- 140 g
- 8.5 cm
- 8.5 cm
- 5.6 cm
- 140 g
- Enclosure Colour
- White
- Localisation
- Worldwide
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 150 Mbps
- Switching Protocol
- Ethernet
- L2TP, PPPoE, FTP
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
- Frequency Band
- 2.4 GHz
- Performance
- Capacity
- Status Indicators
- Power, status
- VLAN support, auto-uplink (auto MDI/MDI-X), manageable, IPv6 support, firmware upgradable, WISP mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Auto Traffic Classifier (ATC), Multiple SSID support, IPv4 support
- Encryption Algorithm
- AES, TKIP, WPA2, WPA-PSK
- Authentication Method
- RADIUS, LDAP, Basic Service Set Identifier (BSSID), Active Directory
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at
Aerial
- Antenna
- Internal
- Gain Level
- 2 dBi
- 3 x 100Base-TX - RJ-45 , 1 x 100Base-TX (WAN) , 1 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX (management)
- PoE
- 0 °C
- 50 °C
- 15 - 95% (non-condensing)
