Brand
Ring Stick Up Cam Battery - White
Quicklinx: FGDKWS00 Mfr#: 8SC1S9-WEU0
Add security anywhere – inside or out – with the versatile Stick Up Cam Battery. Its wire-free design means you can put it where you need it and move it when you need to. Place it on a flat surface for flexibility or mount it to a wall for a more permanent solution. With Stick Up Cam Battery, you’ll always be connected to home so you can see what’s happening at anytime.
Goes everywhere. Sees everything.
Add eyes and ears inside or out with the versatile camera that goes almost anywhere. With countless placement options and customisable motion settings, you can find your perfect setup for you and your home.
Cover every corner.
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control. One simple app.
Connected Devices - Connect to all your Ring devices to see what’s happening from a single dashboard and to control everything from one simple app.
Ring Stick Up Cam Battery - 3rd Generation - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type
Wall mount, ceiling mount
5.99 cm x 5.99 cm x 9.7 cm
White
Wireless
Camera
Colour - Day&Night
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
1 - micro-USB charge cable - external
Smartphone Monitoring
1-year warranty
Environmental Parameters (operating)
-20.5 °C - 48.5 °C
Audio Support
Camera Mount Type
Wireless
5.99 cm
5.99 cm
9.7 cm
Europe
Camera
Colour - Day&Night - fixed - outdoor, indoor - weatherproof
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
116
Vertical Field of View (degree)
65
Network Interface
Mounting kit, base cover, rechargeable battery, security sticker, base pad
1 x micro-USB charge cable - external
White
1
Android 5.0 or later, Apple iOS 9.1 or later
Internet of Things (IoT)
Alexa
Limited warranty - 1 year
-20.5 °C
48.5 °C
