Ring Floodlight Cam Wired Pro 2nd - Black
Quicklinx: HTXXWS00 Mfr#: B0CG6T4QNH
Compatible With: Alexa
29 In Stock
£183.33 ex VAT
£219.99 inc VAT
Discover the Ring Floodlight Cam Wired Pro, an outdoor surveillance solution designed by Amazon.com. This network camera is engineered to enhance the security of your home or business with its array of features. Experience peace of mind with 1080p HD video capture, HDR, and Color Night Vision, ensuring clear and detailed footage day or night. The camera's 140° horizontal and 80° vertical field of view offers comprehensive coverage of your property.
Equipped with two LED floodlights producing 2000 lumens and a built-in siren of 110 dB, the Floodlight Cam Wired Pro deters intruders effectively. Advanced motion detection technologies, including 3D Motion Detection and radar sensor, provide precise alerts, while customizable motion zones ensure you're only notified when it matters. With two-way audio capability, you can communicate with visitors from anywhere.
Integration with Alexa makes this camera a seamless addition to your smart home ecosystem, offering voice control and intelligent automation. Its weather-resistant design ensures reliable operation in temperatures ranging from -20.5 °C to 48 °C, making it a versatile choice for outdoor security. Whether you're looking to protect your home or business, the Ring Floodlight Cam Wired Pro offers a powerful combination of technology and convenience.
  • Weather resistant design
    Built to withstand the elements, this outdoor camera operates in a wide range of temperatures from -20.5 °C to 48 °C, ensuring reliable security through varying weather conditions.
  • Enhanced security features
    Equipped with 2 LED floodlights producing 2000 lumens, a built-in siren of 110 dB, and advanced motion detection capabilities including 3D Motion Detection and radar sensor, this camera provides comprehensive security coverage.
  • Superior connectivity
    Supports multiple IEEE 802.11 network interfaces including ac, b, g, and n, ensuring robust and reliable Wi-Fi connectivity for seamless video streaming.
  • Innovative surveillance technology
    Features like Audio+, Bird's Eye View, Color Night Vision, HDR, Live View Control, Smart Zoom, and advanced pre-roll enhance the surveillance experience with detailed and clear video capture, day or night.
  • Smart home integration
    Fully compatible with Alexa, this IoT-ready camera integrates seamlessly into your smart home ecosystem, allowing for voice control and smart automation for an enhanced user experience.
Ring Floodlight Cam Wired Pro - network surveillance camera
Network surveillance camera - fixed - outdoor - weather resistant
Audio
Yes: two-way audio capability
Camera Mount Type
Wall mount, ceiling mount
32.6 cm x 20.2 cm x 21.7 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Intelligent Assistant
Alexa
Voltage
AC 100-240 V
Radar sensor, HDR, Live View Control, Colour Night Vision, advanced pre-roll, built-in siren (110 dB), 2000 lumens floodlight sensor, 2 LED floodlight, Smart Zoom, Advanced Motion Detection, customisable motion zones, 3D Motion Detection, Bird's Eye View, Audio+, motion-activated notifications
1-year warranty
Environmental Parameters (operating)
-20.5 °C - 48 °C
Audio Support
Camera Mount Type
Wireless
32.6 cm
20.2 cm
21.7 cm
Camera
Colour - Day&Night - fixed - outdoor - weather resistant
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Video Capture Resolution
1920 x 1080
Lens Construction
Horizontal Field of View (degree)
140
Vertical Field of View (degree)
80
Network Interface
Mounting bracket, screws, installation accessories
Power adapter AC 100-240 V
Software Included
Ring Protect (30 days trial), Ring App
Internet of Things (IoT)
Alexa
Limited warranty - 1 year
-20.5 °C
48 °C
Brand: Ring
