Ring Alarm Keypad (2nd Gen)
Quicklinx: GBQ2WS00 Mfr#: B08J66XTLJ
Type: Keypad
Compatible With: Alexa
£34.89 ex VAT
£41.86 inc VAT
The Ring Alarm Keypad is an indoor control panel that lets you easily arm and disarm your Ring Alarm system from inside the home. It plugs into any standard power outlet and comes with a rechargeable internal battery for a wire-free solution.
  • Effortless control
    The Ring Alarm Keypad offers seamless integration into your home security system, allowing for easy arming and disarming. Its wireless connectivity ensures that you can place it anywhere in your home for convenient access.
  • Adaptable to your environment
    Designed to operate between 0°C and 40°C, the Ring Alarm Keypad is built to withstand a variety of environmental conditions, ensuring reliable performance no matter where you live.
  • Versatile power options
    With the flexibility to be powered by either a battery or a power adapter, the Ring Alarm Keypad ensures your home security system remains operational, even in the event of a power outage.
Ring Alarm Keypad - 2nd Generation - keypad - Z-Wave - white
Keypad
Environment
Indoor
Functions
Alarm control
Power Source
Battery, power adapter
Wireless - Z-Wave
Input Type
Keypad
White
1-year warranty
10 cm x 14.9 cm x 2.3 cm
Keypad
Environment
Indoor
Functions
Alarm control
Power Source
Wireless - Z-Wave
Max Range Open Space
76 m
Away Mode, Home Mode, panic button, wall mountable, arm/disarm function
Control Unit
Input Type
Keypad
Rechargeable Battery
Rechargeable
Battery Included
Power adapter, wall mount bracket
White
Warranty
1-year warranty
10 cm
14.9 cm
2.3 cm
Type: Keypad
Brand: Ring
