Where space is at a premium, the compact A4 black and white multi-functional, the Aficio SP SP 5210sf is ideal. It delivers 4-in-1 printing, copying, scanning and faxing to meet all your document needs. Packed with features usually expected only from larger MFPs, it is smaller but work just as hard. Your busy office or workgroup gets fast, affordable and versatile devices that can expand from desktop models to mighty four-tray, floor-standing powerhouses.
Big performance for small spaces
Where space is at a premium, the compact A4 black and white multi-functional, the Aficio SP 5210sf is ideal. It delivers 4-in-1 printing, copying, scanning and faxing to meet all your document needs. Packed with features usually expected only from larger MFPs, it is smaller but work just as hard. Your busy office or workgroup gets fast, affordable and versatile devices that can expand from desktop models to mighty four-tray, floor-standing powerhouses. -
Versatile and flexible
The standard model offers a single tray with 550-sheet capacity which is great for either a desktop or a small office environment. Larger workgroups can extend the MFPs with three further paper trays to a maximum 2300-sheet capacity for different paper types. The SP 5210sf has a built-in fax as standard. -
Maximize your workspace and minimize the effort
Space-efficient, the compact A-4 MFPs don't intrude on valuable workspace in the office. Set-up and operation are simple and straightforward. It also gives you a large dimension touch panel with a tilting function that can be adjusted for ease of use by any operator. -
Spend time working, not waiting your turn
You can access the copying, scanning or faxing functions whenever you need them, whether or not other jobs are being printed. Stacks of loose paper documents can be scanned straight to your desktop or a folder. You'll also have no problem faxing from your PC and organizing, editing and sending files with the onboard scanning tools. While a standard USB print connection saves valuable time and enhances productivity. -
Keep confidential documents confidential
You have the choice of a full suite of security tools to keep your data safe. For example, hard copies won't print until a PIN is entered and you can restrict the use of the multifunctional devices to approved groups or individuals. Plus watermarks can be embedded in the media to prevent unauthorized copying. -
Control costs and save more
The range is designed to minimize TCO with many money-saving features to reduce unnecessary paper consumption. Two-sided duplex printing, for example, is automatic and cuts down on paper use and costs. Print volumes can also be controlled to prevent unauthorized use or over-use to save on costs.
- Ricoh SP 5210sf - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 50 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 50 ppm
- Max Printing Resolution
- Up to 1200 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 600 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, thin paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 600 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- Office Machine Features
- Scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 46 cm x 51 cm x 68.6 cm
- 47 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - monochrome
- Interface
- USB, LAN, Wi-Fi
- Standard Memory
- 1 GB
- Max Supported Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 50 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Preset Enlargements
- 141%, 200%
- Preset Reductions
- 50%, 71%, 93%
- Maximum Copies
- 999
Printing
- Up to 50 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Total Memory Capacity
- Up to 320 pages
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- Legal
- Min Media Weight
- 52 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 216 x 900 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 600 sheets
- Input tray - 550 sheets - Legal (216 x 356 mm) weight: 52 g/m² - 220 g/m² , Bypass tray - 100 sheets - 216 x 900 mm weight: 52 g/m² - 220 g/m² , ADF - 50 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 52 ppm (Letter A) - B/W , Printing: up to 50 ppm (A4) - B/W , Copying: up to 50 ppm
- 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition
- Software Included
- Web Image Monitor, DeskTopBinder Lite, Remote Communication Gate S Pro, App2me, SmartDeviceMonitor
- Voltage Required
- 1500 Watt
- Power Consumption Standby
- 8 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 7.5 sec
- Consumables Included
- 1 x toner cartridge (black)
- Supported Windows 7 Features
- Windows HD Imaging
- ISO 9001, ISO 14001, ISO/IEC 19752
- 46 cm
- 51 cm
- 68.6 cm
- 47 kg
