Canon imageRUNNER C1225iF Colour Laser Multifunction Printer
Quicklinx: BLFVWS00 Mfr#: 9548B007
£708.10 ex VAT
£849.72 inc VAT
The imageRUNNER C1225iF is a feature rich A4 color multifunctional device, providing fast and efficient document handling ‘out of the box’ so you can focus on your business priorities.
  • Productive and flexible
    The imageRUNNER C1225iF is a productive, color A4 multifunctional device, offering up to 25 pages per minute, providing high quality color output. A 8.9 cm color touch and swipe user interface provides user friendly and simple operation. Flexible mobile printing and scanning capabilities such as Apple AirPrint, Mopria printing as well as mobile printing and scanning apps support mobile worker efficiency. Users can also easily scan and send documents directly to a variety of destinations including email and shared folder.
  • Professional and cost efficient
    The cost efficient imageRUNNER C1225iF uses Canon's V color (Vivid & Vibrant) imaging technology to ensure your documents impress and stand out from the rest. The imageRUNNER includes a full set of toner bottles in the box, allowing you to use the device straight away. Reduce paper consumption with automatic double-sided print, copy and scan functionality.
  • Suitable for all businesses
    With a compact design, the imageRUNNER C1225iF fits into various office environments and is suitable for small workgroups within any size organization, either as a desktop or as a floor standing device thanks to its flexible paper cassette options. Equipped with the imageRUNNER controller, it seamlessly integrates with IT environments, and supports standards such as PCL and Genuine Adobe PS.
  • Environmentally responsible
    This ENERGY STAR qualified device offers a class-leading TEC rating and consumes just 1W or less in sleep mode. It is designed to be more energy efficient, reducing power consumption in use and environmental impact. The imageRUNNER C1225iF demonstrates strong environmental credentials by also qualifying for the stringent Blue Angel certification.
Canon imageRUNNER C1225iF - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 25 ppm (mono) / up to 25 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 dpi
Display
3.5"
Original Size
128 x 140 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
98.4 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, punched paper
Standard Media Capacity
650 sheets
Max Media Capacity
1200 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to FTP, Canon's V2 color imaging technology
AC 230 V (50/60Hz)
51.1 cm x 54.9 cm x 61 cm
44 kg
Environmental Standards
ENERGY STAR Qualified
Manufacturer Warrnty
2 Years
Fax Type
Plain paper
Printing Technology
Laser - colour
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Preset Enlargements
141%, 200%, 400%
Preset Reductions
25%, 50%, 70%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, UFRII
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 512 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
281 station(s)
Broadcast Transmission
310 stations
Fax forwarding, Dual Access, fax memory backup
Document & Media Handling
Min Original Size
128 x 140 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
98.4 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 98.4 x 148 mm, 98.4 x 190.5 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
650 sheets
Max Media Capacity
1200 sheets
100 sheets
250 sheets
Paper cassette - 550 sheets size: 98.4 x 190.5 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98.4 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 250 sheets , ADF - 50 sheets size: 128 x 140 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m²
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (A4) - colour , Printing: up to 25 ppm (A4) - B/W duplex , Printing: up to 25 ppm (A4) - colour duplex , Printing: up to 26 ppm (A5) - B/W , Printing: up to 26 ppm (A5) - colour , Printing: up to 26 ppm (A5) - B/W duplex , Printing: up to 26 ppm (A5) - colour duplex , Scanning: up to 25 ipm (A4) - B/W , Scanning: up to 9 ipm (A4) - B/W duplex , Scanning: up to 25 ipm (A4) - colour , Scanning: up to 9 ipm (A4) - colour duplex , Copying: up to 25 ppm (A4) - B/W , Copying: up to 25 ppm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 3 x USB host - 4 pin USB Type A
Security Protocols & Features
LDAP, Secure Print, SMB authentication, IPsec, 802.1x, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1.5 kW
Power Consumption Standby
30 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
34 sec
First Copy Out Time B/W
8.4 sec
First Copy Out Time Colour
10.5 sec
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
IPv6 Ready
ENERGY STAR Certified
51.1 cm
54.9 cm
61 cm
44 kg
Shipping Width
62.6 cm
Shipping Depth
72 cm
Shipping Height
84.7 cm
Shipping Weight
50.5 kg
Sound Emission
30 dB (idle) / 50 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
Service and Support
2 Years
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Functionality: Fax
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: £500 - £750
