Home or small office printing is taken to the next level with the Canon i-SENSYS LBP621Cw - ultra-reliable, simple to operate, single-function compact color laser printer.
Canon i-SENSYS LBP621Cw in More Detail
The Canon i-SENSYS LBP621Cw A4 Colour Laser Printer is an excellent choice for small or medium businesses. The compact design and simple operation make it easy to use.
Easy to use
With an intuitive LCD screen, it is easy to set up jobs and control the printing functions. All-in-one Canon cartridges make it straightforward to replace the ink as needed, while Auto Seal removal technology makes it quick and simple to swap out cartridges. The single-function laser printer is simple to use and you can print wirelessly for even more convenience.
High-quality prints
Fast and efficient printing makes this printer perfect for your small business or home office. When paired with high-quality print cartridges from Canon, you'll discover crisp and clear printouts whether you're producing reports, documents or graphics-rich publications.
Space-saving design
This compact colour printer measures 430 x 418 x 287mm making it perfect for smaller sized offices. It can seamlessly fit into a home office so you have a highly efficient printer ready to go. Weighing just 15.5kg, the printer can easily be moved into a new position whenever you need it.
Efficiency built in
This high-quality printer allows you to quickly and efficiently print multiple-page documents. Connect wirelessly and protect your sensitive data with a Secure PIN. An output of 18ppm with standard A4 print jobs makes this an ideal printer for many types of home users and businesses.
Plus, with a large 250-sheet paper tray, you will have to refill less often. Airprint and Mopria allow you to use multiple devices to send jobs directly to the printer. The LCD display is simple to use so you can see the status of a job and set up the next one with ease.
                Efficient connectivityWith a range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi(n), alongside mobile printing capabilities through Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer offers seamless integration into any home or office network.
                High-quality printingLeveraging Canon's Ultra Fast Rendering (UFRII) technology alongside support for JPEG, PDF, and TIFF language simulations, the Canon i-SENSYS LBP621Cw delivers crisp, vibrant color prints with a maximum duty cycle of 30,000 pages per month, ensuring reliability for all your printing needs.
                Versatile media handlingAccommodates a wide range of media sizes from A4 and Legal to envelopes and more, with a 250-sheet paper cassette and a 1-sheet multipurpose tray. This flexibility makes it ideal for various printing tasks, from detailed reports to marketing materials.
                Eco-friendly operationDesigned with energy efficiency in mind, the printer features a low power consumption in sleep mode of just 0.8 W and a modest 8.5 W in standby, contributing to lower energy bills and a reduced environmental footprint.
- Canon i-SENSYS LBP621Cw - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 355.6 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 38 ppm - B/W - A5 (148 x 210 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 38 ppm - colour - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, cards, recycled paper, thin paper, postcards, glossy paper, coloured paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet paper cassette, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.9.5 or later, Apple macOS 10.14 or later
- 2-year warranty (France - 3 years with product registration)
- 43 cm x 41.8 cm x 28.7 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- First Print Out Time B/W
- 10.4 sec
- First Print Out Time Colour
- 10.5 sec
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 355.6 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 250 sheets
- Media Feeders
- Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray: 1 - 1 sheet - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray: 1 - 100 sheets
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 30000 pages
- 250 - 2500 pages
- Networking
- Print server
- Secure Print
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 910 pages - Canon 054 Starter , 1 x toner cartridge (cyan) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (magenta) - up to 680 pages - Canon 054 Starter , 1 x toner cartridge (yellow) - up to 680 pages - Canon 054 Starter
- Power Device
- Power supply
- Frequency Required
- 50/60 Hz
- 850 Watt
- Power Consumption Stand by
- 8.5 Watt
- Power Consumption Sleep
- 0.8 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 52 dB
- 43 cm
- 41.8 cm
- 28.7 cm
- 15.5 kg
