The low total cost of ownership of the SP 3600DN A4 printer make it the ideal device for low volume, cost-effective desktop printing. With a warm-up time of only 13 seconds and print speed of 30 pages per minute with double-sided printing at 15 ppm the SP 3600DN is the perfect solution for personal printing or networked for use by small workgroups.
The SP 3600DN is ready to print in seconds generating high quality prints in no time. Double-sided printing as standard saves paper and reduces costs. Operating costs are also kept low with a typical electricity consumption value of 1.4 KWh, among the lowest in its sector.
- Ricoh SP 3600DN - printer - B/W - LED
- Printer Type
- Workgroup printer - LED - B/W
- 14.5 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- Processor
- 500 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper, thick paper, thin paper, middle thick paper, preprinted paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 350-sheet input tray
- Monthly Duty Cycle (max)
- 50000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- 37 cm x 39.2 cm x 26.8 cm
- Printer Type
- Workgroup printer - LED - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Fonts Included
- 45 x PCL , 136 x PostScript 3 , 13 x Intellifonts
- Media Handling
- Processor
- 500 MHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 52 g/m² - 162 g/m²
- 350 sheets
- Media Feeders
- 1 x automatic - 350 sheets - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m² , 1 x automatic - A4 (210 x 297 mm) weight: 52 g/m² - 162 g/m²
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 125 sheets
Duty Cycle
- 50000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 989 Watt
- OS Required
- 37 cm
- 39.2 cm
- 26.8 cm
- 14.5 kg
